Browse Forums Windows & Doors Re: obscure glazed windows 4May 20, 2012 7:58 am camelia Thanks Aussie, what are 'r' codes? If the average eye height for an australian male is 1.7 (average height of males= 1.8 m) then 1.6 m is inadequate. It is 1.7m, so only above average males can perve... apparently they discovered all peeping Toms are short guys... There's some info here... Quote: Overlooking A habitable room window or raised open space of a building on an allotment must not provide a direct line of sight into the secluded open space or a habitable room window of an existing dwelling on an adjoining allotment within a horizontal distance of 9 metres (measured at ground level) of the window or raised open space. The direct line of site referred to must be measured with a 45° angle from the plane of window or perimeter of the raised open space and from height of 1.7 metres above the floor level of the habitable room or raised open space. A habitable room window complies if: (a) it is offset a minimum of 1.5 metres from the edge of one window to the edge of the other; or (b) it has a sill height at least 1.7 metres above floor level; or (c) it has obscure glazing at any part of the window below 1.7 metres above floor level; or (d) it is obscured by a permanent and fixed screen which has no more than 25% of its area open. A raised open space complies if the direct line of sight into the habitable room window or secluded private open space on the adjoining allotment is obscured by a permanent and fixed screen which has no more than 25% of its area open. A window referred to above may be openable provided that when open the obscure glazing does not permit a direct line of sight into secluded private open space or habitable room window. This does not apply to a new habitable room window that faces a property boundary if: (a) there is a visual barrier at least 1.8 metres high at the boundary; and (b) the floor level of the room is less than 800mm above ground level at the boundary. A raised open space as indicated above means; (a) a landing with an area more than 2m² and with a floor height of 800mm or more above natural ground level at the boundary; or (b) a balcony, terrace, deck or patio with a floor height of 800mm or more above natural ground level at the boundary. If the design does not comply with this a consent and report of the relevant council will be required. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: obscure glazed windows 6May 25, 2012 12:39 pm Is it compulsory to have obscured glass in the bathrooms if both bathrooms are on the side of the house and there is a colorbond fence? Re: obscure glazed windows 7May 27, 2012 10:23 am ed @ ecoclassic camelia Thanks Aussie, what are 'r' codes? If the average eye height for an australian male is 1.7 (average height of males= 1.8 m) then 1.6 m is inadequate. It is 1.7m, so only above average males can perve... apparently they discovered all peeping Toms are short guys... There's some info here... Quote: Overlooking A habitable room window or raised open space of a building on an allotment must not provide a direct line of sight into the secluded open space or a habitable room window of an existing dwelling on an adjoining allotment within a horizontal distance of 9 metres (measured at ground level) of the window or raised open space. The direct line of site referred to must be measured with a 45° angle from the plane of window or perimeter of the raised open space and from height of 1.7 metres above the floor level of the habitable room or raised open space. A habitable room window complies if: (a) it is offset a minimum of 1.5 metres from the edge of one window to the edge of the other; or (b) it has a sill height at least 1.7 metres above floor level; or (c) it has obscure glazing at any part of the window below 1.7 metres above floor level; or (d) it is obscured by a permanent and fixed screen which has no more than 25% of its area open. A raised open space complies if the direct line of sight into the habitable room window or secluded private open space on the adjoining allotment is obscured by a permanent and fixed screen which has no more than 25% of its area open. A window referred to above may be openable provided that when open the obscure glazing does not permit a direct line of sight into secluded private open space or habitable room window. This does not apply to a new habitable room window that faces a property boundary if: (a) there is a visual barrier at least 1.8 metres high at the boundary; and (b) the floor level of the room is less than 800mm above ground level at the boundary. A raised open space as indicated above means; (a) a landing with an area more than 2m² and with a floor height of 800mm or more above natural ground level at the boundary; or (b) a balcony, terrace, deck or patio with a floor height of 800mm or more above natural ground level at the boundary. If the design does not comply with this a consent and report of the relevant council will be required. Ed hi would you know if this requirement is also applicable if there's no existing dwelling in the area? (i.e. we are the first ones to build on our block) thanks in advance Re: obscure glazed windows 8May 27, 2012 11:18 pm sencillez hi would you know if this requirement is also applicable if there's no existing dwelling in the area? (i.e. we are the first ones to build on our block) thanks in advance Yes, it applies to you too... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16243 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16161 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10483 |
