Browse Forums Landscape & Garden Design Re: How to build a retaining wall 2Apr 20, 2012 2:57 pm This is also something we want to try ourselves though ours would need to be a little higher. Re: How to build a retaining wall 3Apr 20, 2012 3:04 pm I actually like block retaining walls you can bend them rather than just have them straight and they don't rot. There is a design guide you download at this link: http://www.boral.com.au/masonry-design- ... 20home.asp The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to build a retaining wall 4Apr 21, 2012 4:41 pm This is our local landscape store... where we actually got our landcape supplies. My partner used their videos to guide his block retaining wall construction. They also have videos on timber sleeper and log retaining walls. http://www.centenarylandscaping.com.au/ ... gssleepers Our new house - moved in but so much more to do! https://forum.homeone.com.au/viewtopic.php?f=31&t=31696&p=442009#p442009 Re: How to build a retaining wall 5Apr 21, 2012 4:48 pm miss_new_home_owner This is our local landscape store... where we actually got our landcape supplies. My partner used their videos to guide his block retaining wall construction. They also have videos on timber sleeper and log retaining walls. http://www.centenarylandscaping.com.au/ ... gssleepers Thank you so much Very helpful Re: How to build a retaining wall 6Apr 22, 2012 5:31 pm When building concrete sleeper retaining walls get a peice of timber 5-10mm longer than your sleepers and use that to get your post spacing right. Re: How to build a retaining wall 7Apr 24, 2012 7:36 am I am going to build a retaining wall later using steel "Retain its" http://www.whiteswires.com.au/Products/WhitesWirescatalogue/tabid/123/ProdID/236/bRetain-iT-range--Converts-Sleepers-into-Wallsb.aspx Perfect for a straight wall, ours is going to be three sleepers high down the side of the house and one at the back for a raised garden bed Re: How to build a retaining wall 8Apr 24, 2012 9:57 am Victoria_g06 I am going to build a retaining wall later using steel "Retain its" http://www.whiteswires.com.au/Products/WhitesWirescatalogue/tabid/123/ProdID/236/bRetain-iT-range--Converts-Sleepers-into-Wallsb.aspx Perfect for a straight wall, ours is going to be three sleepers high down the side of the house and one at the back for a raised garden bed Thanks for that ... could be very helpful! For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5196 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45833 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16156 |
