Browse Forums Flooring & Floor Covering Re: How to refund flooring? 2Apr 05, 2012 1:57 pm CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: How to refund flooring? 7Apr 05, 2012 8:26 pm CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: How to refund flooring? 12Apr 10, 2012 9:26 am CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: How to refund flooring? 14Apr 10, 2012 11:22 am CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: How to refund flooring? 20Apr 10, 2012 3:26 pm baekjh Does it matter? I made the purchase decision based on the sample they presented at that time. I did not conduct the exact same drop test but tried running my finger nail through it and dropped an object to see if it's hard enough. It does matter IMO. As I stated above, SBG is considered only of medium hardness and rates as 9 on the Janka test. So unless there is a gaurentee somewhere that states your floor will be a minimum hardness of X, or the supplier does a huge jesture of good will here your wasteing your time. Every peice of timber is not tested for hardness, if so you would probably find there are cuts that are softer than 9 and cuts that are much harder than 9. Thats not a defect or a fault, thats timber. My guess is the sample is simply the latter. Don't get me wrong, i'm the first to make a stand if I believe something is not as it should. But as they say pick your battles. 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6240 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15975 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6498 |
