Browse Forums Kitchen Corner Re: Help re good bright under cupboard lights 2Mar 03, 2012 4:14 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Help re good bright under cupboard lights 6Mar 04, 2012 3:56 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Help re good bright under cupboard lights 7Mar 15, 2012 1:02 am Hi Chippy Got the Hettich lights- very bright, thanks! Now need to figure out how to dim them as I see they are dimmable. Must I get a special dimmer, or can my electrician use a standard dimmer? Also, as these lights are 2.3 watts each, I think one 15 watt driver should be fine to control 5 lights, leaving 1 light to use elsewhere with the other driver ( as they come in a pack of 3 including the driver ). Is that right? Re: Help re good bright under cupboard lights 8Mar 15, 2012 2:33 am Good to hear! I've always found them to be some of the brightest out there. All my clients that have requested lights have been very impressed with them. As far as a dimmer goes I've never actually bothered to dim them, just on and off. Your sparky should know if you need a leading edge or trailing edge dimmer. I know it depends on the type of transformer. As regards running 5 lights off the one transformer once again I'd check with your sparky. I usually just run 3 lights per transformer but I'm sure you'd be fine with more. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 990 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3590 |
