Browse Forums Building A New House Re: House Build Perth WA - Lorimer 7Feb 29, 2012 4:55 pm Congrats on the build. Before you sign the final plans make sure you check absolutely everything - even down to where your outdoor garden taps are located. I notice you are obtaining a quote for AC. Make sure the final plans incorporate the design for the AC including slab penetration points, service ducting, bulkheads if required and so on. The basic smart wiring I assume is about 4 points, such as 2 data points, foxtel and so on. For the 4-5k they charge it is not worth it. No real standard exists for structured cabling systems. Include additional power points in the garage other than what is currently in place for the garage door motor. Also for your outdoor areas include additional power points. With the LED lights, are these just 240/12V downlights with LED bulb? You can always retrofit later if this is the case. Make sure you have sufficient lighting everywhere especially if using downlights. Make sure the downlight also suits being placed in the slab. Good luck with Lorimer Re: House Build Perth WA - Lorimer 8Feb 29, 2012 5:09 pm Thanks for the advise, I think for smart wiring we will just get conduits in so it can be done later. Not fuessed for this as wireless is suffecient for now. Agreed i need to add some more powerpoints, in the agarge and inside. As for the outdoor power points i will put in two junction boxes, one at the front and rear for future cabling. The LED lights i was going to buy online, like the Brightgreen D900, but ive also seen the Osrams at Bunnings for $25........ Not sure how they perform though. http://www.electricalproducts.com.au/br ... light.html And the AC is something ill need to check on. There is an AC duct on the second story, i just need to find out about it getting to the Theatre room which is under the slab. Re: House Build Perth WA - Lorimer 9Mar 01, 2012 3:12 pm I would definitely go the bgreen d900. I have them in my place. we put them in last year and they are great, loads of light and heaps cheaper to run. I wouldn't bother cheaping out on the osrams. My sisters husband thought our were great as well so he put in brightgreen lights too, but they just put these ones (see link) into their old fittings. I wonder if it would be cheaper to put in halogen fittings then run these replacement brightgreen LEDs? http://www.electricalproducts.com.au/br ... -mr16.html good luck! Re: House Build Perth WA - Lorimer 10Mar 02, 2012 11:24 am Another consideration while sorting out your plans is a security system. With a 2 storey house, if you want to hardwire the sensors you should be thinking about this now and where the services with conduit will run. You can also implement a wireless solution if you want the flexibility. Either solution will still require a phone point (monitored system) and power point say in the WIR where you place the control box. If you plan on getting ADSL also make sure you have a central filter for the non-ADSL lines. Small things but it will save you issues later Re: House Build Perth WA - Lorimer 11Mar 02, 2012 5:43 pm Good point OyabunG. Ill take that into consideration. Anyway just received our Prelim plans with full specs of everything. Very exciting to see the full layout. Of the house. It inlcudes elevations of all the interior areas such as cubpoard heights etc etc. This weekend they have the Ideal home show on at the Convention centre in Perth so im going to take my plans and go talk to everyone i can about quotes and ideas! Cant wait! Re: House Build Perth WA - Lorimer 12Mar 09, 2012 3:13 pm Daedalus although much harder (possibly more costly) to run the cabling after handover on a suspended slab, it is possible. you run into all sorts of irritations if you're trying to rework the entire ground floors lighting arrangements after handover. Not to mention you are completely ignoring the structural integrity of the slab and possibly voiding warranties. If you have a drop ceiling or a cavity for the LED light to fit into then yes installing after handover is possible. If they are talking about chasing conduit into the slab, you should consult the engineer. For most 2 storey's in Perth with a concrete upper floor, they cast the light fittings into the slab and skimcoat the underside of the slab Re: House Build Perth WA - Lorimer 14Mar 23, 2012 7:08 pm We have decided on a few items in the house even though we havnt started Pre-Start yet. Siemens Stove (Glass, easy to clean) Model: 900mm Avanteguard Gas on Glass Cooktop ER947501UC Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Siemens Rangehood (Matching the stove) Model: LC958BB60 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Undermount Sink - Oliverei MO70UR including accessories Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Reeces Vanity in downstairs toilet due to minimal space Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Saturn clipsal switches (Main areas only) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Samsung Electronic Door (Samsung SH5120) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Corinthian Front Double Door Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Venecia Toilet Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: House Build Perth WA - Lorimer 16Mar 25, 2012 11:42 am Hi There, Regarding your switches, not sure if you are aware but clipsal have just released a touch sensitive switch. not sure of the cost but may be worth looking into for the main areas. Great choices BTW. I will also be building in Perth, if I can ever get the bits and pieces of variations pinned down..... Cheers Mark Re: House Build Perth WA - Lorimer 17Mar 27, 2012 9:42 am AussieMark Hi There, Regarding your switches, not sure if you are aware but clipsal have just released a touch sensitive switch. not sure of the cost but may be worth looking into for the main areas. Great choices BTW. I will also be building in Perth, if I can ever get the bits and pieces of variations pinned down..... Cheers Mark Hmm sounds expensive, im on a budget. As i said im only putting the Saturn in the main areas of the house which only includes the living areas such as entry, kitchen, dining, living and sitting room. Re: House Build Perth WA - Lorimer 18Mar 27, 2012 4:25 pm Barnseee AussieMark Hi There, Regarding your switches, not sure if you are aware but clipsal have just released a touch sensitive switch. not sure of the cost but may be worth looking into for the main areas. Great choices BTW. I will also be building in Perth, if I can ever get the bits and pieces of variations pinned down..... Cheers Mark Hmm sounds expensive, im on a budget. As i said im only putting the Saturn in the main areas of the house which only includes the living areas such as entry, kitchen, dining, living and sitting room. Do you know the cost for Saturn switches? Re: House Build Perth WA - Lorimer 19Mar 27, 2012 6:35 pm http://www.saturnshop.com.au/clipsal-saturn-switches/ Just bought one since i wanted to see what it looks like. I will be buying the rest closer to completion of the house. I just then supply my electrician the switches. Re: House Build Perth WA - Lorimer 20Apr 30, 2012 1:07 pm Pre Start We finally started Pre-Start on Saturday 14h April 2012. Our first appointment was with the Interior/Exterior decorator I was quite surprised that we had an independent person (Not from Lorimer) to help us with choosing our house colouring. We meet up with Jade form InDesign on the Saturday morning and she helped us to choose the colouring item parts of the house. The meeting seemed to go so quickly as your looking at things and choosing items you think you want in your house. Well as long as you know what you want you will be fine. She told us about how many people come in and have arguements right in front of her as they couples can never make up their mind. We successfully got through with little trouble. I think everyone has their difference in opinion but as long as you can come to a conclusion im sure you will be fine we its your turn to build. Our pre start session was split in two. The reason being is because you could be there all day trying to decide on what you want and beacuse there are so many items you go through in pre start. These are the items we went through with the Decorator. Saturdays Meeting External rendering – Two Colours Roof colour Down pipe colour Door colours and door handles Stone bench tops Kitchen cupboard colours Glass splash back Bathroom tiles and cupboards Laundry tiles and cupboards, Walk in Pantry Bench and Tiles Window Frame Colour Entry Door Type and Colour Lorimer Pre-Start The next pre start meeting was held at their head office in Balcatta, Monday 16th April 2012. This meeting was to go through the rest of items not covered in the above meeting. We met up with Emily on the Monday morning and went through some pre revisions on our choices as above. The next step was to go through other items listed below. Luckily we had completed most of them a while back as you can see from my previous post. The choices seemed failry easy, there were a few things that we missed but that was expected. Items we went through at Pre Start Pre Start House Alterations Extra Quotes Appliances Balustrade selections Taps Sinks Basins Robe Shower Screen finish and type Glass Finish Electrical Air Con Other requirements Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19889 1 10688 hi guys. Please be nice. First time home builder in Qld. I would like some feedback please on whether I should build my granny flat first before my main house at the… 0 5327 |
