Browse Forums Building Standards; Getting It Right! Re: Building code re fans in bathroom 5Feb 16, 2012 3:48 pm Whether or not there is a toilet such rooms require 'mechanical ventilation' under the code. i.e. ehaust fans incorporated with light switches, displacing the required volume of air / hour. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Building code re fans in bathroom 6Feb 16, 2012 4:18 pm If you have a development that has required a Basix certificate, then it will specify if it needs to be externally ducted or ok to duct to roof space. If your eaves are accessible then ducting to here is the easiest option (for external, single story). Most importantly, in my opinion, is to ensure that any fan you install has anti draft flaps (close when fan is off). Otherwise all your heat in winter goes straight out that 2-300mm hole. If you are renovating and dusting externally is an issue, just duct to roof space and run the duct to the eave space . Any condensation will be ok there as they are lined with fibro. Re: Building code re fans in bathroom 7Feb 17, 2012 5:38 pm Thanks so much for your replies. The house is 14 years old so no BASIX applies. The bathroom is on the 2nd floor, with a colorbond roof and no eaves. I'm not sure then where I can vent to? Re: Building code re fans in bathroom 9Feb 18, 2012 2:16 am ShellyC Thanks so much for your replies. The house is 14 years old so no BASIX applies. The bathroom is on the 2nd floor, with a colorbond roof and no eaves. I'm not sure then where I can vent to? In all honesty, it can probably just vent into the roof. Unless you have 10 people showering it isnt going to be too bad. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8463 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16571 |
