Browse Forums Kitchen Corner Re: Squareform Bench Edges 2Feb 11, 2012 11:15 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Squareform Bench Edges 4Feb 12, 2012 3:25 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Squareform Bench Edges 5Feb 12, 2012 4:23 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Squareform Bench Edges 6Feb 12, 2012 5:39 pm But laminex has far far more colours than 31 and these cant be square formed. The OP asked about Squareform which is a 5mm radius not 7mm or 9mm. You said "I assume that all post forming laminates can be square formed" which isnt right. The laminate has to be thin enough to be rolled around such a tight radius. Laminex has 216 listed laminates under the bench top section with only 30 or so available for squareform. Formica has a similar product called TightForm which is a 7mm radius and is available in 97 colours. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Squareform Bench Edges 7Feb 12, 2012 5:58 pm Squareform is a registered trademark of Laminex so no other laminate brand can do a Squareform bench. What the OP was asking is if other laminate suppliers can do a bench that looks similar (tight radius). As I pointed out (and you mentioned again) formica have 97 colours that can be tight formed and having had a look at the Polytec site it seems that most of their bench top laminates that can be tight formed. Whether it is 5 or 7mm the look is very similar. I think my initial response was fairly accurate, maybe I should have said that most laminate brands will have products that will give a similar look. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Squareform Bench Edges 8Feb 12, 2012 7:50 pm Thanks CEK and Chippy I appreciate your responses. I understand that Squareform is a Laminex TM but as long as I can get a similar look I will be happy with that. Just looking to get a squarish edges rather than the rolled edged or the seams along the top. But will know now that If I want the sharper square look I will have to stick with the laminiex squareform colours. Thanks guys Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11813 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31332 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3843 |
