Browse Forums Building A New House Re: Who's building with Clarendon?? 121Jan 24, 2012 7:10 am PAs? My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Who's building with Clarendon?? 123Feb 05, 2012 6:33 pm Well, after a lot of thought it looks like we are going to go with a slightly customised Dalkeith 29. I'll probably have a thousand questions as I go along. For the moment, I have just one: - How much did you pay to upgrade your bricks beyond the standard PGH & Austral range that Clarendon have? Re: Who's building with Clarendon?? 124Feb 06, 2012 4:32 pm About 3 to 5 K, depending on the brick and the amount of area you have. Worthwhile if there is abick you really like. You can always get them to quote it up for you then roll it back if it is out of your budget. My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Who's building with Clarendon?? 125Feb 06, 2012 5:02 pm Thanks for the reply, they quoted us $5k for a slightly better PGH Brick (it was only in the middle range according to the sheet) but the reason why I'm annoyed is because according to the retail price list the standard brick range and this particular brick are both exactly the same price. For that reason alone I'm tempted to go with my second choice which is very similar and within the standard range of Austral bricks, unless I can bargain with Clarendon to give me my choice of PGH brick without charge. Re: Who's building with Clarendon?? 126Feb 06, 2012 5:30 pm We are building with C too... so far so good. check us out here: viewtopic.php?f=31&t=54042 Re: Who's building with Clarendon?? 127Feb 06, 2012 5:52 pm rjc786 Well, after a lot of thought it looks like we are going to go with a slightly customised Dalkeith 29. Out of interest, what changes are you making to the Dalkeith 29? I've been thinking about that one myself. Re: Who's building with Clarendon?? 128Feb 06, 2012 6:06 pm Fredescu rjc786 Well, after a lot of thought it looks like we are going to go with a slightly customised Dalkeith 29. Out of interest, what changes are you making to the Dalkeith 29? I've been thinking about that one myself. There are two configurations we're currently deciding between; rough changes are: - Design flipped to better suit our block - Replace Alfresco area with more living space (I don't have much use for the extra space now but you never know what the future holds) - Add Bedroom wall to close off the ensuite - Turn "Living" room into Home Theatre - Remove some windows - Replace double doorway in main bedroom with single doorway - Slightly wider W.I.R. Entry - 1200mm Front Entry Door We're also considering altering the main bedroom wall so that there is more space in that room however I need to discuss cost with Clarendon next weekend. We've opted for the Capri Facade in full brick but I haven't reflected that change on the below images (It has a larger Porch area) These are rough unfinished photoshops that show the two layouts we're deciding between: Re: Who's building with Clarendon?? 130Feb 25, 2012 7:39 pm Back to the question about PAs.....do you get that on a fixed price contract....what should I be expecting when it comes to handover? My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Who's building with Clarendon?? 132Mar 17, 2012 8:33 am Ok, long time since a post. It has been a long hard slog, however, we are finally out of council. We have had to add wall articulation in the form of two brick piers and some cladding attached to the brick wall between the piers approximately 5.2m2 of cladding. The quote was in excess of $2300 this seems very expensive for what it is. Re: Who's building with Clarendon?? 133Apr 13, 2012 7:38 pm Right, we originally had our Dalkeith 29 plans re-drawn like so: and we then flipped it around to better suit our block, with a nice offset on one side to allow a generous space for entertainment area or whatnot All was well until CDC came into the picture to give me a headache. The draftsperson then told me that I need to find another 1.68m of front setback thanks to my Neighbour's house and the original calculations being wrong. Rained on my parade pretty hard but we re-worked the dimensions in a way that while it meant I lose the Home Theatre Living Room, and the open-plan living area is smaller, we gained larger bedrooms and a slightly larger garage as a trade-off There's a restriction zone on one side of my land due to a green electrical box on my neighbour's property. Originally we were told this is no big deal as we'll just have to increase the fire rating for the one corner of the house that intrudes on this slightly (on the ammended plan it was around 1.5m sq). Now the drafting people have delivered more headaches with the news that thanks to the garage door not having a proper fire seal we need to flip the house around to avoid the restriction zone. This makes it sit like so: Pretty much screws my backyard plans up entirely.. won't be able to do much with either side of the house. And my bedroom is closer to the mysterious green electrical box. I'm hoping then that my blockout shutters on the windows help shield the electro magnetic fields... Ammended house plan (much smaller than I originally would have liked) Due to personal reasons a double storey is out of the question, so I suppose this is about the best we can do given the situation.... Might try to fight them on the fire rating for the garage thing, I really want to have the house flipped as originally planned Re: Who's building with Clarendon?? 134Apr 13, 2012 10:22 pm Hi rjc786 Not sure which council you are with but have gone and had a chat with them. Maybe worthwhile. Commando. Re: Who's building with Clarendon?? 135Apr 17, 2012 9:59 pm All For all building in Victoria with Clarendon, I just found out that they are shutting their shop here in Victoria and will only be operating in NSW and QLD. Even their website no longer provides the option to select VIC. I had my 90 day inspection today and the warranty officer informed me that they were not sure whether the maintainence dept would be retained here. So, as you would already do, make sure everything that needs to be fixed, you get it in writing from them or even an email. Cheers Re: Who's building with Clarendon?? 136Jul 21, 2012 10:35 pm Hi all, just wondered if there is a topic for Clarendon Upgrade Costs? I see other people have posted upgrade costs for other builders but none for Clarendon... Lexia Slim Twist with Beechwood Homes http://houseoflexia.blogspot.com.au/ https://www.instagram.com/natlyn7/ Re: Who's building with Clarendon?? 138Jul 29, 2012 10:24 pm rjg, sent back through the thread and could only find bits and pieces.. Updated cost lists would be great and very helpful Lexia Slim Twist with Beechwood Homes http://houseoflexia.blogspot.com.au/ https://www.instagram.com/natlyn7/ Re: Who's building with Clarendon?? 139Jul 31, 2012 10:07 am Natlyn, I don't have a price list as such- they don't seem to have one you request a change they price a change. This is a little backwards in terms of upselling. Many people feel if they need to ask they can't afford it. Funnily we upgraded quite a lot and I don't know if it was age, or they didn't want sale to fall over they kept trying to talk us out of our fireplace and bi-fold doors!! Very odd behavior. In terms of upgrades though, some things are quite reasonable- even the credits back- and others are ridiculous. EG, we got 10k back for the conditioner (6hp) which we are replacing with a 13k 19hp aircon unit. Odd thing is the aircon came in one of the 995 packages- try telling me the price isn't built in to house cost! One of the ridiculous things was colourbond originally something like 15k argued, got quotes from an independent roofer and he quoted 18k to do entire job. Now putting colourbond up is quicker and cheaper in terms of less trussing. So where is the cost? I put this to them, with details of independents quote and pointed out that isn't including a credit for the tiles. Another week went by, with a few offerings until we got it to a more reasonable cost (8k). This is still expensive as it should be pretty much a straight swap given efficiencies as per above, but at some point you have to move on! My point..... if it seems expensive- it probably is, fight it, justify it, and they are likely to meet you- at least half way. They have on many occasions with us. the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6731 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7847 |
