Browse Forums Building A New House Re: Steel lintel not needed above rear door of garage? 2Jan 23, 2012 2:28 pm H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: Steel lintel not needed above rear door of garage? 3Jan 23, 2012 2:56 pm NO EXPECTATIONS, NO DISAPPOINTMENTS! Build Thread: viewtopic.php?f=31&t=27441 Landscaping Thread: viewtopic.php?f=19&t=43969 Re: Steel lintel not needed above rear door of garage? 13Jan 24, 2012 9:51 am B STAR usually 820mm doors are done without lintels if using a steel frame, anything bigger will require a lintel. Is this going by regulation/Australian Standards? I met with the SS today and he said he is waiting for the engineer to inspect to see if a lintel is required over the rear garage door. I can't see why it wouldn't be needed but will wait to hear back. Re: Steel lintel not needed above rear door of garage? 15Mar 13, 2012 2:29 am I try to to put lintels above doors each and every time, if possible, in order to avoid complications that may follow. Jason Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 15163 The frame work needs to be fully and adequately supported as they are most of the time the load bearer. A steel angle bolted to slab edge and bottom plate could do the… 1 934 |
