Browse Forums Interior Decorating Lounge Re: Ask your “Curtain Questions Here” 221Jan 23, 2012 1:41 pm For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Ask your “Curtain Questions Here” 222Jan 23, 2012 1:41 pm The track "looks too skimpy" - lengthwise or thickness? the later would be a separate issue/concern If you are wanting them wider it is likely they will need to be altered/remade which be either less fullness or more fabric required. You need to consider what was asked/quoted for when purchased, compared to what has been delivered. I consider many factors when deciding how far the curtains should extend past the window which forms part of my consultation, as I design and construct I understand how the finshed product looks, which a sales person may not have. I can't speak for how other workrooms operate. Re: Ask your “Curtain Questions Here” 223Jan 23, 2012 1:45 pm Yes we are wanting them wider so the curtain can be pulled back off the window ... our mistake was not to get enough detail of the gap she was talking about between the curtain on the door and the curtain on the window when she was measuring up .. in fact there wasn't a lot of detail in the quote about sizes so lesson learned and hence why I sent her a follow up email!! We realise it will cost more for the extra track and curtain but it's worth it to get it right. Thanks for your input ... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Ask your “Curtain Questions Here” 224Jan 26, 2012 3:32 am Hi there 4walls, I have an activity room that I've been quoted for, but I keep getting told different things. So I hope you can help... I am thinking of getting either a roller blind for this window or a Roman blind. My question should the below window have two blinds that would meet in the middle OR should the blinds be kept in line with the windows. So in this case there would end up being 3 blinds. What is correct? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Ask your “Curtain Questions Here” 225Jan 30, 2012 11:23 am Further to my queries above you can see from this pic that only 200mm was allowed on each side to pull the curtain back which was clearly not enough as quite a bit of the window was covered so we have asked for 750mm on each side so the curtain can be pulled all the way back ... hopefully she gets it right this time! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Ask your “Curtain Questions Here” 226Jan 30, 2012 6:42 pm Angelblue - For looks 3 would be better than 2, however is likely to be more costly. Mclaren - I glad for you that the workroom/designer is sorting it out for you. They should be able consider all the variables to estimate its' stack back. From guesstimating the size of the window from the picture 75cm each looks to be generous. Re: Ask your “Curtain Questions Here” 228Feb 15, 2012 2:30 pm Hi, I can see this thread has been posted long time back, but would like to get some information about the curtains. At this stage I am getting quotes from some of the curtain companies & appreciate if any of you could advise me of some curtain makers in Melbourne. Porter Davis - Wembley 35 Contract Signed: 17 Aug 2010 Handover: 12 Aug 2011 Re: Ask your “Curtain Questions Here” 229Mar 18, 2012 8:33 am I personally love the rubber backed curtains with full pleats on a classical Mahoganny rail with Pelmet. This is only because our house is crammed with antiques but once again, this is also what I grew up with Dean Dean Cato - CEO Murano Italian Decor and Glass Lights http://www.italiandecor-glasslights.com salesandsupport@italiandecor-glasslights.com Re: Ask your “Curtain Questions Here” 230Mar 19, 2012 9:48 am 4walls Angelblue - For looks 3 would be better than 2, however is likely to be more costly. Mclaren - I glad for you that the workroom/designer is sorting it out for you. They should be able consider all the variables to estimate its' stack back. From guesstimating the size of the window from the picture 75cm each looks to be generous. Here's an updated pic of the curtains now with the correct track and extended on the window side ... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Ask your “Curtain Questions Here” 231Mar 28, 2012 2:54 pm Hi all, Please help me in finding curtain installers...I have my own curtains got them from overseas for my new house...I need to install sheer, curtain and valance on each window....As my house nearing completion I am looking for some curtain installers but no luck in finding...could someone pls suggest if you know anyone Thanks Heaps Re: Ask your “Curtain Questions Here” 233Mar 28, 2012 4:47 pm Hi, I've posted a question a while back about box window treatments on another thread but not had a reply. My question is will shutters work on an east facing master bedroom- box window will get all morning sun. I was thinking blockout blinds of some sort, but the light lines at edges are really annoying.
Can shutters be used on the return? I have never had shutters before but love the look of them. What do you think? Can't send a pic because the house isn't built yet. Re: Ask your “Curtain Questions Here” 234Mar 29, 2012 10:36 am [quote="4walls"]Mclaren - I take it you are happy with the alterations?quote] Yes very happy ... love the curtains now and it feels so cosy when they are closed - will be great in winter! For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Ask your “Curtain Questions Here” 235Apr 03, 2012 8:32 am Mclaren 4walls Mclaren - I take it you are happy with the alterations? Yes very happy ... love the curtains now and it feels so cosy when they are closed - will be great in winter! and they look gorgeous! Re: Ask your “Curtain Questions Here” 236Apr 03, 2012 9:59 am Thanks Tam .... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Ask your “Curtain Questions Here” 237Apr 03, 2012 9:23 pm Hi I think the old style curtains with rubber backing are very stylish and just something that I was bought up with Dean Dean Cato - CEO Murano Italian Decor and Glass Lights http://www.italiandecor-glasslights.com salesandsupport@italiandecor-glasslights.com Re: Ask your “Curtain Questions Here” 238Apr 04, 2012 5:58 am Treeseachanger Hi, I've posted a question a while back about box window treatments on another thread but not had a reply. My question is will shutters work on an east facing master bedroom- box window will get all morning sun. I was thinking blockout blinds of some sort, but the light lines at edges are really annoying. Can shutters be used on the return? I have never had shutters before but love the look of them. What do you think? Can't send a pic because the house isn't built yet. Treeseachanger Have you had a reply yet? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Ask your “Curtain Questions Here” 240Apr 04, 2012 3:01 pm I think this can be done. Your installer may need to add whats called Light Stops around the surround of the window to fill any gap if the size is not normal. Get a measure and quote, they will soon tell you if it will work or not. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Ardo That is so funny! I wonder how many people know who Larry Haun is these days. I have a couple of young guys we call Mo 1 & Mo 2 who run a crew of 6 boys and… 9 15699 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15661 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10718 |
