I have a query regarding drainage.
It seems that, in their infinate wisdom, my builder has done some excavation work on my level block before putting the slab down. This makes my block the lowest and therefore all of the surrounding blocks are a touch higher and rain loves to sit on my block...
Does anyone know what obligations the builder has to properly drain the block and should the slab be above the soil height.. at the moment if they build up the block as they suggest they will before hand over. the slab will be not visible and in the next rain all the water will get into the brick work which i'm sure can't be good
