Browse Forums Paving & Concreting Re: Cost of Sealing Coloured Diveway 15Jan 01, 2012 4:10 pm That looks so good, the sealer has really brought out the color in it, I have just been told that without the sealer every bit of dirt and fluid will soak into and stain the concrete. Re: Cost of Sealing Coloured Diveway 16Jan 01, 2012 6:26 pm Ok all done I can say that I'm 95% happy with it.. there are a few parts that are lighter than the rest but generally it is cohesive. Things I would do differently.. I think acid washing is the most important part. If we sealed this earlier it probably would have been easier because it has only gotten lighter. When acid washing try and get it even all over.. the 1st coat of sealer helps but you can tell the much lighter parts. Hopefully this was helpful to someone, and I can say that I've done this myself and not had a tradie stuff it up! Re: How to seal your coloured driveway Step by Step 17Mar 22, 2019 3:55 pm Would anyone know why my driveway has come up with white marks on some sections? My driveway is about 6 months old & has been sealed by our builder. Just curious if anyone has seen this before? Also are cracks like that normal? Thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5243 4 14421 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11933 |
