Browse Forums Paving & Concreting Re: Cost of Sealing Coloured Diveway 13Dec 31, 2011 10:16 am excited Hi, I'm also very interested to see how the end result goes, I am going to have colored concrete as well on my drive and the verandahs around my house, it will be a big job What happens if you don't seal the concrete? Oh yes it is a big job.. We have gone through 25 litres of acid and it looks ok, not crash hot.. Will post a pic later Our concrete got poured in early June dark charcoal , now it has turned a light grey almost light blue hue. Not sure what would happen if I didn't seal it.. The concreter didn't explain anything! Re: Cost of Sealing Coloured Diveway 14Dec 31, 2011 8:03 pm Well the actual sealing was easier than I expected. Supplies After acid wash ready for sealer. After Sealer You can tell there is a big difference -darker; still a bit patchy but the final coat should do the trick. For the sealer I used a roller - 5cm Nap (Smallest there is) This first coat has to be 20% solvent to a rate of 7 meters sq per litre. I thought the area was 50 sq m which would have meant 5 litres sealer - 2 litres solvent but we ended up using 1.25 litres solvent and 3.25 litres sealer Next coat is tomorrow night pure sealer. Then technically you have to wait 72 hours before driving but I will have to leave the garage for work Monday - around 36 hours. Mondays good weather should help it along though Re: Cost of Sealing Coloured Diveway 15Jan 01, 2012 4:10 pm That looks so good, the sealer has really brought out the color in it, I have just been told that without the sealer every bit of dirt and fluid will soak into and stain the concrete. Re: Cost of Sealing Coloured Diveway 16Jan 01, 2012 6:26 pm Ok all done I can say that I'm 95% happy with it.. there are a few parts that are lighter than the rest but generally it is cohesive. Things I would do differently.. I think acid washing is the most important part. If we sealed this earlier it probably would have been easier because it has only gotten lighter. When acid washing try and get it even all over.. the 1st coat of sealer helps but you can tell the much lighter parts. Hopefully this was helpful to someone, and I can say that I've done this myself and not had a tradie stuff it up! Re: How to seal your coloured driveway Step by Step 17Mar 22, 2019 3:55 pm Would anyone know why my driveway has come up with white marks on some sections? My driveway is about 6 months old & has been sealed by our builder. Just curious if anyone has seen this before? Also are cracks like that normal? Thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5264 4 14471 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11974 |
