Browse Forums What's New Re: Grout Colour Sealing DIY Kits from Grout Perfect 2Dec 24, 2011 6:20 pm Hi Craig Would you recommend applying the Group Perfect product for a new floor? Is it safe to use procelain tiles with coloured grout (e.g. Ardex FSDD 337 - Travertine http://www.tilegrout.com.au/home/ardex-grout-fs-dd and http://www.ardexaustralia.com/pdf_bro/0026.pdf )? Also, what is the estimated cost of a kit? We have about 120m2 of main flooring to do and then the wet areas also. Thanks, Jaans Re: Grout Colour Sealing DIY Kits from Grout Perfect 4Jan 03, 2012 7:08 am Jaans Hi Craig Would you recommend applying the Group Perfect product for a new floor? Is it safe to use procelain tiles with coloured grout (e.g. Ardex FSDD 337 - Travertine http://www.tilegrout.com.au/home/ardex-grout-fs-dd and http://www.ardexaustralia.com/pdf_bro/0026.pdf )? Also, what is the estimated cost of a kit? We have about 120m2 of main flooring to do and then the wet areas also. Thanks, Jaans Hi Jaans Sorry that I have not got back to your post as I have been on holidays. Grout Perfects colour sealer is a must for new installs, the kits range from $38.50 up to $250 depending if you need to clean before applying. If you are sealing around 120 m2 than you will need 3 x 250 ml bottles that is if you have 600 x 600 porcelains which I am guessing. Craig Re: Grout Colour Sealing DIY Kits from Grout Perfect 5Jan 20, 2012 9:08 am Is is suitable for grouting inbetween glass pool tiles (for pool feature)? "Whoever says sunshine brings happiness has never danced in the rain!" Re: Grout Colour Sealing DIY Kits from Grout Perfect 6Jan 20, 2012 10:00 am kezacheekychicken Is is suitable for grouting inbetween glass pool tiles (for pool feature)? Hi Grout Perfects colour sealer is not designed to sit under water in a pool sorry. Craig Re: Grout Colour Sealing DIY Kits from Grout Perfect 7Jun 22, 2012 9:53 pm @Craig Thanks for your post earlier. The guys have just finished the grouting today, floors and wet areas! How long does grout take to set / dry and how long should I wait before applying Grout Perfect? Do you still think I need about 3x250ml for the main floors? They are all 600x300 tiles with a 3mm gap (same for wet areas). I have two bathrooms where the walls tiled to the ceiling, do you reckon a bottle each is enough? I'm guessing that one bottle for the floors of both will suffice as that'll be a smaller surface.
Sorry for the 20 questions, I just wan't make sure I get it right. Alternatively, I noticed you are in Brisbane (we are in Moggill). Would you be interested in doing the sealing of our tiles, and if so, what would you charge? Re: Grout Colour Sealing DIY Kits from Grout Perfect 9Jun 25, 2012 6:59 am Hi Jaans The amount of sealer required depends on the size of the area ( floor ) you have. One 250 ml bottle is more than enough for each bathroom. I will post out to you today your colour swab brochure. You will have to wait 48 hours before you can colour seal new grout. If you wanted an applicator to do it for you they charge around $22 per sq metre for a 600 x 300 tile that includes cleaning as well. Craig Re: Grout Colour Sealing DIY Kits from Grout Perfect 11Feb 03, 2014 8:21 am Hi does anyone have any experience with this product? Thanks Building The Vines with Dale Alcock in Aveley Contract signed 15/5 Electrical Prestart 24/5 Prestart 13/6 Earthworks started 06/8 Slab Down 09/8 Re: Grout Colour Sealing DIY Kits from Grout Perfect 12Sep 08, 2015 8:10 am We have just recently launched our new website www.groutperfect.com.au and now have 24 colours for you to choose from. Grout Perfect`s grout colourant is long lasting and keeps grout looking new. Perfect for the tradesman or DIY market. Please make sure your grout is recessed just below the tile before ordering. We used a smaller qld builder who went bankrupt about 12 months after completion of ours. It was a shame as they were good and relatively cheap and I would have used… 3 5335 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6850 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 2633 |
