Browse Forums Renovation + Home Improvement Re: Timber floor for workshop 2Dec 01, 2011 5:16 am Landscape Design & Construction http://cherub.squarespace.com/ Re: Timber floor for workshop 12Dec 07, 2011 11:00 am Go steel my friend. -Steel sub frame, steel C channells maybe. -Steel checkerplate finish. -When your done with it all you can disassemble and move it, or flog it for scrap. Good Luck. Pat. Re: Timber floor for workshop 13Dec 08, 2011 12:29 am Cheers Pat, I was thinking exactly that just yesterday, the only problem I can think of with checker is rolling engine stands and cranes around on it would be difficult. The steel frame is the go I reckon, I still think that 22mm tounge and groove flooring on top would be allright, thats pretty thick. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16924 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3605 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 8324 |
