Browse Forums Flooring & Floor Covering Re: Install bamboo floor before or after? 2Nov 23, 2011 6:07 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Install bamboo floor before or after? 4Dec 01, 2011 1:12 pm Hi Chris, It all really depends on what you prefer if price is not an issue. If you want something that looks professional, then installing your bamboo flooring first then your kitchen will give a really quality appearance and look to your kitchen that can't be achieved if the flooring was installed after the kitchen. Also, another benefit of this if that in the future if your cabinets or whatnot need adjusting or fixing or alterations, it is more possible to do as there won't be missing areas that don't have the bamboo flooring. The only downside to this is that if something were to happen to your floors, it won't be possible to fix without affecting your kitchen as well. My suggestion is that if you are going for appearance, then I would go with second option of installing the flooring prior to the kitchen. Best of luck! Re: Install bamboo floor before or after? 5Dec 30, 2011 6:42 pm ChrisBirmele We are planning to install a bamboo floor (strand-woven, tongue-groove) over our existing cypress wooden floor. Before we do, we will install a new kitchen and here is my question: a) would you install the kitchen on top of the existing timber floor (then add ~15 mm in height to compensate for the bamboo flooring installed later) b) would you install bamboo (or some other) flooring prior to installing the kitchen? I am NOT concerned about which option is cheaper or easier to do, I am interested in a professional quality job. Thanks in advance Chris Hello Chris The kitchen should be installed before the bamboo floor is installed. Main reason is that you don`t want the kitchen people to damage your new bamboo floor. Also if you don`t want beading around the kitchen the kick boards can be installed after the bamboo floor as been installed. Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Re: Install bamboo floor before or after? 6Jan 18, 2012 7:51 pm Hi ChrisBirmele, Bamboo King is spot on. Kitchen first, floor last. Leave the kick boards off and have them retro fitted by the cabinet maker to then not require beading. You can't tell the difference and it means if you have a flood or something terrible with your floor then you will not have to remove your entire kitchen to access your floor. Best wishes for your project. CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4329 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8646 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16565 |
