Browse Forums Building A New House Re: Double Storey Home - Increase first floor ceiling height 4Nov 21, 2011 5:42 pm AussieMark Hi There, I originally specified 34c for lower floor which is 2,914mm and 32c on upper floor which is 2,743mm. This has now changed a little as I am sinking the rear of my house with a split level. So front will be 32C and back will be 38C and first story will be 32c. Not sure where you are located but there are R-code restrictions that require approval to go beyond 6m. I think mine will be only an inch over and I have a neighbour who is about 0.5m over. The measurement is taken from natural ground level which will be on the elevation and site survey. Cost wise its is not that much in relation to the whole house. The standard course is 28C so I am paying around 15K i think to have the extra height. The house is a reasonable size so I guess it is a function of how many more bricks are needed. Total house with garage is around 530M2. Personally I prefer the higher ceilings as I have always lived in houses with them. I guess it will add to heating and cooling costs however I am also getting double glazed to help from that angle. Not sure if it helps but if it were me I would want the higher. The reason we did not make the upstairs higher is because it it mainly bedrooms and games area. All living and entertaining areas are in the 38c section. Cheers Mark Thanks for the input Mark! Good point about the restrictions - I just checked - Maximum height of wall or ceiling for double storey home in our council area is 6.5m (9-10m for roof ridge line) - I'll have to check whether this limits our ceiling height choices I like higher ceilings as well but haven't really seen any homes with higher first floor ceilings so it's a bit difficult to visualize at the moment - we will be having all the bedrooms and one living space upstairs Any other opinions out there? Building ??? with ??? Re: Double Storey Home - Increase first floor ceiling height 5Nov 21, 2011 6:00 pm We've gone 2590 both up and downstairs as I prefer that to 2440. Would love to have had 2700+ but our council has a 7.5mt limit to overall house which means to have the 2590 up and down we have had to reduce out roof pitch to 18 degrees. Didn't mind the roof line change as it's two storey, if it had been a single storey house I'd be very disappointed with a reduced roof pitch. In the end when I was lamenting not going to the highest ceiling height I went back to the display home and was really happy with the ceiling height that we've chosen. One of the big changes we should have made with our last house was the increased ceiling height, it really changed the feel of the house. Don't forget to increase your door heights so that they look right with the increased roof line. Good luck deciding Re: Double Storey Home - Increase first floor ceiling height 6Nov 21, 2011 6:00 pm We've gone 2590 both up and downstairs as I prefer that to 2440. Would love to have had 2700+ but our council has a 7.5mt limit to overall house which means to have the 2590 up and down we have had to reduce out roof pitch to 18 degrees. Didn't mind the roof line change as it's two storey, if it had been a single storey house I'd be very disappointed with a reduced roof pitch. In the end when I was lamenting not going to the highest ceiling height I went back to the display home and was really happy with the ceiling height that we've chosen. One of the big changes we should have made with our last house was the increased ceiling height, it really changed the feel of the house. Don't forget to increase your door heights so that they look right with the increased roof line. Good luck deciding Re: Double Storey Home - Increase first floor ceiling height 7Nov 21, 2011 6:32 pm buildingbee We'll be putting 2.7m ceilings on the ground floor - first floor is standard 2.4m but we are thinking about increasing this to 2.59m - has anyone else done this (or higher)? Was it worth it? Any pics?? Where are you building? The M3tr1con display home at Kellyville Ridge (The Ponds) all have 2.590m. For 2.7m first floor, you might need to go to Bella Vista Water display home, called Homequest. I think there's 1-2 display home (Young homes and one more builder that I forgot that has 2.7m for 2nd floor). Re: Double Storey Home - Increase first floor ceiling height 8Nov 21, 2011 7:24 pm willcres buildingbee We'll be putting 2.7m ceilings on the ground floor - first floor is standard 2.4m but we are thinking about increasing this to 2.59m - has anyone else done this (or higher)? Was it worth it? Any pics?? Where are you building? The M3tr1con display home at Kellyville Ridge (The Ponds) all have 2.590m. For 2.7m first floor, you might need to go to Bella Vista Water display home, called Homequest. I think there's 1-2 display home (Young homes and one more builder that I forgot that has 2.7m for 2nd floor). Awesome! Just what we need - thanks willcres! We are building in Sydney South but have been to Kellyville many times =) We have not seen the M3tr1con homes in this location before but a visit is definitely on the cards now! Thanks for the tip on Homequest display - will definitely be going there as well! Building ??? with ??? Re: Double Storey Home - Increase first floor ceiling height 9Nov 21, 2011 7:39 pm Mark, We are virtually the same as you! We have 2.7m at the front of our bottom storey and a 600 split so have 3.3m in our back living dining and kitchen area then 2.7m upstairs, I can't wait to see the 3.3m ceilings, I. Think they will be amazing AussieMark Hi There, I originally specified 34c for lower floor which is 2,914mm and 32c on upper floor which is 2,743mm. This has now changed a little as I am sinking the rear of my house with a split level. So front will be 32C and back will be 38C and first story will be 32c. Not sure where you are located but there are R-code restrictions that require approval to go beyond 6m. I think mine will be only an inch over and I have a neighbour who is about 0.5m over. The measurement is taken from natural ground level which will be on the elevation and site survey. Cost wise its is not that much in relation to the whole house. The standard course is 28C so I am paying around 15K i think to have the extra height. The house is a reasonable size so I guess it is a function of how many more bricks are needed. Total house with garage is around 530M2. Personally I prefer the higher ceilings as I have always lived in houses with them. I guess it will add to heating and cooling costs however I am also getting double glazed to help from that angle. Not sure if it helps but if it were me I would want the higher. The reason we did not make the upstairs higher is because it it mainly bedrooms and games area. All living and entertaining areas are in the 38c section. Cheers Mark Re: Double Storey Home - Increase first floor ceiling height 10Nov 21, 2011 8:42 pm I have 2.55 downstairs and 2.4 upstairs, wish I had increased upstairs Re: Double Storey Home - Increase first floor ceiling height 11Nov 21, 2011 9:26 pm buildingbee willcres buildingbee Awesome! Just what we need - thanks willcres! We are building in Sydney South but have been to Kellyville many times =) We have not seen the M3tr1con homes in this location before but a visit is definitely on the cards now! Thanks for the tip on Homequest display - will definitely be going there as well! No problem, buildingbee! Wish I had 2.590m too.... 1 4592 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9982 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81734 |
