Browse Forums Windows & Doors Re: How long does it take to install a window? 6Nov 14, 2011 12:56 pm Art While I'm at it.... How much does a window weigh per sqm roughly? Double glazed obviously weighs a fair bit more? Double glazed 20-25 kgs/m2... more for large commercial and laminated. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: How long does it take to install a window? 7Nov 16, 2011 9:11 pm You can of course just insert the window in the framing 'hole', pack it out with spacers etc and the job is done. But should you be having bricks as the outer skin on your house you might like to consider the brickie and all the work he might have to do around each window. In particular you should be spacing the windows to work bricks either from a corner up to the window or between windows. Properly placed windows can save an awful lot of brick cutting. cheers barkly Re: How long does it take to install a window? 8Nov 17, 2011 6:50 am barkly You can of course just insert the window in the framing 'hole', pack it out with spacers etc and the job is done... Once you have checked it's is square & plumb and it is set back to the plaster, and then checked that the sash or door panel operates - if not readjust. Saves a lot of work for the window service guy. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20643 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8706 Congratulations! Nice to put that to bed before christmas, now you can relax 3 7241 |
