What a great list!
Thank you!
Browse Forums Kitchen Corner Re: Links- Benchtops 23Aug 22, 2011 5:56 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Links- Benchtops 26Nov 02, 2011 8:18 pm I have a question. We have just had our new kitchen put in and the benchtop, Diamond Gloss "Pure Mineralstone", is full of depressions. It's as though the thing has been hit by a hundred golf balls! Any advice? I of course pointed it out to the cabinet maker who said it was a normal thing, caused by the glue, it would be gone in 12 months. Sounds fishy to me. Re: Links- Benchtops 27Nov 23, 2011 9:54 am keebs I have a question. We have just had our new kitchen put in and the benchtop, Diamond Gloss "Pure Mineralstone", is full of depressions. It's as though the thing has been hit by a hundred golf balls! Any advice? I of course pointed it out to the cabinet maker who said it was a normal thing, caused by the glue, it would be gone in 12 months. Sounds fishy to me. Doesnt sound right. Do you have any pictures? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Links- Benchtops 29Nov 30, 2011 9:05 am CC101, try http://www.caesarstone.com.au, many builders in Victoria use this company.
http://www.essastone.com.au is another very popular one. Re: Links- Benchtops 30Jan 16, 2012 7:01 pm hi all, the width of our caesarstone island benchtop is only 750mm - I only realized when we signed the home contract. We just moved in last December and I'm thinking of extending the width to another 100mm or 200mm maybe. Not sure if anyone did the same thing and how does the joint look like, is it too obvious? If we replace the whole caesarstone benchtop it will be more costly. appreciate your opinion. thanks. Re: Links- Benchtops 32Jan 17, 2012 1:27 am hi All my kitchen bench is 2460 mm long and 900 mm wide with 600mm cupboards underneath and 300mm overhang. I had many quotes for 20 mm thick stone. One stone mason mentioned that 300mm overhang part is a little bit much for a 20mm thick stone. The stress resistance of the material would be on the limit. He said we can avoid the problem with a substrate. In this case the cabinetmaker need to install a melamine all around on the kitchen bench and that we should have a 40mm miter edge everywhere to hide that melamine. Only one stone mason had above concern and no one else mentioned that. Will appreciate any opinion / help on this. Re: Links- Benchtops 33Jan 17, 2012 9:44 pm CC101 hi All my kitchen bench is 2460 mm long and 900 mm wide with 600mm cupboards underneath and 300mm overhang. I had many quotes for 20 mm thick stone. One stone mason mentioned that 300mm overhang part is a little bit much for a 20mm thick stone. The stress resistance of the material would be on the limit. He said we can avoid the problem with a substrate. In this case the cabinetmaker need to install a melamine all around on the kitchen bench and that we should have a 40mm miter edge everywhere to hide that melamine. Only one stone mason had above concern and no one else mentioned that. Will appreciate any opinion / help on this. has anyone had any bad experience with such a long bench with 300mm hang and 20mm thick stone?? Any help will be appreciated. Re: Links- Benchtops 34Jan 22, 2012 1:05 pm CC101 CC101 hi All my kitchen bench is 2460 mm long and 900 mm wide with 600mm cupboards underneath and 300mm overhang. I had many quotes for 20 mm thick stone. One stone mason mentioned that 300mm overhang part is a little bit much for a 20mm thick stone. The stress resistance of the material would be on the limit. He said we can avoid the problem with a substrate. In this case the cabinetmaker need to install a melamine all around on the kitchen bench and that we should have a 40mm miter edge everywhere to hide that melamine. Only one stone mason had above concern and no one else mentioned that. Will appreciate any opinion / help on this. has anyone had any bad experience with such a long bench with 300mm hang and 20mm thick stone?? Any help will be appreciated. leni, cuttingedgekitchens,Michelle or any one else - any suggestions please. Re: Links- Benchtops 35Jan 23, 2012 4:05 am CC101...you should start your own thread and ask about it. This really is a thread I started with links only, not conversation. Start your thread with the question and maybe cutting edge will see it. By the way, I suggest colours how they are applied and in what length is up to the kitchen supplier, so I can't help you, sorry. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Links- Benchtops 37Jan 23, 2013 10:34 pm I found a fantastic site that supplys granite and quartz worktops and cut offs. http://www.thegranitehouse.co.uk/ Hope this helps people Re: Links- Benchtops 38Feb 12, 2013 8:38 pm MR2 Not to be a pain, but can you fix up the links in the first post? thankyou muchly! I'm not getting a lot of reply emails from the forum.....which links? If they are not working then maybe the company has made changes to their website? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Links- Benchtops 39Feb 12, 2013 9:04 pm Michelle MR2 Not to be a pain, but can you fix up the links in the first post? thankyou muchly! I'm not getting a lot of reply emails from the forum.....which links? If they are not working then maybe the company has made changes to their website? The Parbury & ceaserstone links in the first page don't work Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Links- Benchtops 40Feb 13, 2013 5:58 am DONE...... Thank you for letting me know, I'll check through the rest later. I've just added Polytec as well Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com |
