Browse Forums Kitchen Corner 1 Oct 27, 2011 11:41 pm . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: 700mm Bench Depth 6Oct 28, 2011 11:17 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: 700mm Bench Depth & Island Width 8Oct 28, 2011 4:24 pm kyton PD - exactly right..... I'm going to forward that to Mrs P_D On a more serious note.......*cough* photos ?? Thanks, P_D (Heck, Even iPhone quality would be great !!! Ta) . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: 700mm Bench Depth & Island Width 9Oct 28, 2011 7:33 pm did a highrise of penthouses with a depth of 700mm base and 400mm overheads. it was good as it got the gas hob away from the glass splashback [150mm regs] standard depth is 600mm as others have pointed out. islands generally 900mm but not uncommon for 750-800mm depths. its pretty much up to the individual / benchtop budget G Re: 700mm Bench Depth & Island Width 11Nov 02, 2011 1:26 pm Can't give photos of mine yet but here is the floor plan. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Pepsi, you can have any size island (within reason) that you want, if you are prepared to pay for it. There just isn't enough room in our kitchen to do it. but the island is 4750mm long so we won't be short of space. Our friends one that is 1200mm wide is great but its hard to use it wisely. They have lots of serving stuff on the far side of ti and its a pain in the butt because of the layout of the kitchen. There are a few spots on the near side to put things but its really wasteful design wise. They bought the place as is so its not their fault but they agree its not optimal. 900mm island gives the minimum space(IMO) for a breakfast bar but I would think 1000mm(400+600) is much better. If I had infinite room I would have 700mm bench on wall with cooktop in it, 1200mm walkway, 1200mm island with 700 working space and 500mm breakfast bar and at least 1500mm walking space/chair space behind. Thats 4600mm and we only have 3820mm. The thing we made sure of is that it would work. We dummied up the room sizes in our old house before we knocked it down. Re: 700mm Bench Depth & Island Width 12Nov 02, 2011 3:56 pm Going for the 600+ benchtops is fine but if you have a floorstanding stove and want the front of the stove to line up with the doors either side, you are either going to have bring it out from the wall, leaving a gap at the rear. Make the benchtop 700mm deep and the problem gets worse. You could of course have the stove back against the wall but then the front of it is back 50-100mm from the cupboard doors. This isn't a problem of course if you have a cooktop with an underbench or wall oven. Island benches should be minimum of 900mm deep preferably 1000mm just for the extra legroom on the dining side. The distance between bench and island in my opinion shouldn't be less than 1200mm. We have friends who entertain a bit in a kitchen with 1000mm space and when there are two in the kitchen it is just that much more of a squeeze to get past especially if the oven or fridge door is open. I also know a couple of kitchen designers who both reckon no more than 1350mm between because then you have to take more than two steps ( something about the work efficiency triangle I suppose ). We're having 1300mm between ours with 1200mm at either end of the island bench. I guess it comes down to your space available and what you are comfortable with. Stewie Re: 700mm Bench Depth & Island Width 13Nov 03, 2011 8:31 pm I have the following: * 720 mm benchtop agianst the wall * 1200 mm gap * 900 mm island (giving a nice 300 overhang) I like the arrangement. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: 700mm Bench Depth & Island Width 15Nov 14, 2011 9:13 pm renomart Casa2 * 720 mm benchtop agianst the wall Nice! I did this mainly for an adequate fridge cavity depth, but it is nice all round Demolition August 2009, Construction Started September 2009, Completed December 2010 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27307 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5417 Thanks again for this information. If you do hear anything different, would be great to know 4 8242 |
