Browse Forums Windows & Doors Re: Cabinet doors sitting wont come out ! (with image) 4Oct 25, 2011 12:12 am The door is easy to remove and I assume that you have already done this. To remove the plastic plate on the side of the carcase I'd drill it out. Where the little indents are is where the dowels that hold it in place are. Just dont drill right through the side of the carcase. It's most likely about an 8mm dowel but I'd start with a 5mm and see if that clears it if not go up to a 6mm then an 8mm. The door can still be used, you just unscrew the 2 screws that hold the hinge to the door and the hinge will lift out of the cup hole. You can then replace the whole hinge and plate with a new one. They only cost a few dollars each. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16408 Hey, I'm wanting to make an above ground pond that will sit on our patio, it will be 2m x 1m x 60cm high. I'm just wanting to run a few things by people to verify my… 0 670 |
