Browse Forums Windows & Doors 1 Oct 24, 2011 6:43 pm Hello everyone, I want to remove a door from my cabinet, and that door includes a "sitting" (i hope thats the word for it) that looks like that: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://imageshack.us/photo/my-images/14/21009434.jpg and with the door attacked it looks like that : http://homeaid.xnet.co.il/content/account/00/10/00/00/zir_aron/1.jpg I tried to pull it out but its really stuck in there. In addition I took out all the outer screws so it seems there are 2 "hidden" screws ... so question is how to take it out ? pull ? if so, how am I suppose to do it ? my hand isn't enough and this thing isn't convinient for pulling (its plastic and becomes slippery after couple of times). Thanks for any help !! Re: Cabinet doors sitting wont come out ! (with image) 2Oct 24, 2011 7:43 pm The hinge mount ( the white plastic part on the cabinet itself ) will have two pins with serrations on them that are forcibly pushed into pre-drilled holes in the side of your cabinet. Try pulling it out and you will end up with a bloody big piece of melamine being ripped out as well - very unsightly. You are better off using a sharp chisel and trying to cut it instead. Stewie Re: Cabinet doors sitting wont come out ! (with image) 3Oct 24, 2011 11:47 pm ![]() The hinge mount ( the white plastic part on the cabinet itself ) will have two pins with serrations on them that are forcibly pushed into pre-drilled holes in the side of your cabinet. Try pulling it out and you will end up with a bloody big piece of melamine being ripped out as well - very unsightly. You are better off using a sharp chisel and trying to cut it instead. Stewie Thanks So it will not come peacfully ? I thought about saving it to use the door elsewhere ![]() Re: Cabinet doors sitting wont come out ! (with image) 4Oct 25, 2011 12:12 am The door is easy to remove and I assume that you have already done this. To remove the plastic plate on the side of the carcase I'd drill it out. Where the little indents are is where the dowels that hold it in place are. Just dont drill right through the side of the carcase. It's most likely about an 8mm dowel but I'd start with a 5mm and see if that clears it if not go up to a 6mm then an 8mm. The door can still be used, you just unscrew the 2 screws that hold the hinge to the door and the hinge will lift out of the cup hole. You can then replace the whole hinge and plate with a new one. They only cost a few dollars each. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16408 Hey, I'm wanting to make an above ground pond that will sit on our patio, it will be 2m x 1m x 60cm high. I'm just wanting to run a few things by people to verify my… 0 670 |
