Browse Forums Flooring & Floor Covering Re: Vinyl Planks Verse Vinyl Sheet 5Oct 01, 2011 1:23 pm Anna Ethos Interiors is a fresh and creative design firm, specialising in online interior design services for clients all over the world. http://www.ethosinteriors.com.au Re: Vinyl Planks Verse Vinyl Sheet 7Oct 12, 2011 5:02 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Vinyl Planks Verse Vinyl Sheet 9Oct 13, 2011 6:28 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Vinyl Planks Verse Vinyl Sheet 10Oct 13, 2011 6:54 pm I have a concrete look vinyl (as well) in my bathrooms and a wide wood look walnut vinyl in the kitchen as I didnt want the hardness of tiles. I am really pleased with them, as I wanted vinyl planks but to exy $$$ Re: Vinyl Planks Verse Vinyl Sheet 11Oct 13, 2011 6:59 pm kitchen floor Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ grey vinyl in wir and bathroom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ it has a slight line through it, like it is a fancy tile but without the grout. not a plain flat grey...if that makes sense! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Vinyl Planks Verse Vinyl Sheet 13Oct 13, 2011 7:49 pm Michelle . The planks themselves are great I love them, but they can only do their job if the surface they are glued onto performs right. Michelle is right. We installed vinyl plank in our previous home which was on stumps. Initally it was great but over time, with the movement, gaps opened up between some of the planks. It seems that gaps developed between the masonite sheets that were nailed to the chipboard flooring and then the gaps could be seen between the planks at these points (so on the edge of two sheets of masonite). I was devastated as we had replaced loose laid vinyl that had gotten holes in it from nails in the chipboard flooring. I was forever having to lift the vinyl and sweep the crumbs etc out from underneath, that was a nightmare! . In the end I had to fill the gaps with a similar coloured caulk. Nobody really noticed but I knew it was there. I have to say we did get lots of comments about the vinyl plank and people were surprised they were vinyl. Good luck with your decision. (If you go the vinyl option don't get it loose laid!!) Re: Vinyl Planks Verse Vinyl Sheet 14Oct 14, 2011 5:53 am Here’s my kitchen vinyl with my kitchen selections sitting on it. All I need is the kitchen…… Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the vinyl I bought yesterday for my wet areas. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Vinyl Planks Verse Vinyl Sheet 15Oct 14, 2011 5:59 am By the way there is a way to fix this issue for you. Get your old floor taken up and have a new timber floor put down. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Vinyl Planks Verse Vinyl Sheet 16Oct 15, 2011 11:52 pm If you want vinyl plank then go for it. You should not be installing vinyl flooring directly onto a chipboard, plywood or timber floor without an u'lay. I know you can buy the felt backed products from just about all the suppliers now, but we still glue it down as looselay in my opinion is unprofessional. If the floor isn't flat then it is supposed to be sanded flat. If the floor is not structually sound, then you make it sound. We glue, staple or coil nail gun nearly every floor we install hardboard, plywood, mdf or F/C sheet onto. Your other alternative is looselay vinyl planks. You have the choice of Freefit, Polyflor's Park Lane or the Karndean Looselay vinyl planks. On the choice of vinyl flooring in a wet area ie Bathroom, Ensuite, Toilet or Laundry, How is the waterproofing being done to meet the Required Aus Standards? I have sold & installed abit of flooring in the last 15 or so years. Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8823 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4851 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15561 |
