Browse Forums Home Theatre & Automation 1 Jul 11, 2011 9:40 pm Re: Need a HDMI Cable? ... read this first! 7Jul 15, 2011 4:18 pm Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Need a HDMI Cable? ... read this first! 14Sep 20, 2011 2:24 pm The HDMI cables at The Cable Connection are cheaper and every bit as good if not better than what I saw on the EzyHD site... Re: Need a HDMI Cable? ... read this first! 15Apr 19, 2012 10:35 am A further HDMI issue... There have been reports on some electronics service sites of EXPENSIVE HDMI cables actually causing problems & reducing the quality of video. The problem was with extra thick "monster" style cables which it is thought may have too much capacitance. In the cases given, fitting a cheaper cable solved the problem. Apparently it is a hit & miss situation whether such a cable will cause a problem even with two supposedly identical signal sources & TVs. One may work fine & the other won't. Regards, Brian. Re: Need a HDMI Cable? ... read this first! 16Jul 13, 2012 11:43 pm Hi Brian, It is a balance getting it all right. Lucky for me I don't have this "Monster" of an issue! Re: Need a HDMI Cable? ... read this first! 17Jul 30, 2012 10:55 pm Remarkable..............Thanks for the info Matt Building in Blackwood Park 2012/13 Land settled 8/8/12 Contract signed 6/11/12 Encumbrance approval 24/12/12 Development Approval 24/4/13 Slab Poured 8/7/13 Re: Need a HDMI Cable? ... read this first! 19Aug 13, 2013 10:29 am Not quite as old, but still an old post. Again why bother??? Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ 11 41777 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7390 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8999 |
