Browse Forums Kitchen Corner Floor first or Kitchen Cabinets first 3Sep 15, 2011 9:27 am Also as an ex construction project manager, floor first. Reason. The right floor will last a lifetime, the kitchen cabinets probably will need updating Dave Goralski Coolabode Automation Award Winding Home Automation solutions http://www.coolabode.com.au http://www.facebook.com/coolabodeaustralia http://au.linkedin.com/in/davegoralski 0428-819-340 Re: Floor first or Kitchen Cabinets first 4Sep 15, 2011 12:26 pm I prefer the floor first. It looks neater and gives you a bit more room for one of those new tall dishwashers if you're ever going to get one. Re: Floor first or Kitchen Cabinets first 5Sep 15, 2011 5:24 pm Floor first! It gives the best finish and saves problems in the long run. You will get a far better finish if the kickboards are scribbed to the floor rather than running the floor to them. If you to the floor after the kitchen you end up with a section behind the kickboards lower than the rest of the floor. Imagine what happens if you get a pipe burst or a leak. You have created a well behind the kickboard that the water sits in and is very hard to get out. FLOORS FIRST EVERYTIME. Anyone that says otherwise is trying to make life easy for them selves and doesnt care about the finished product! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floor first or Kitchen Cabinets first 7Oct 06, 2011 5:07 pm aaadistributor . We have several physical locations in Philadelphia.[/b] Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9943 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39464 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16537 |
