Browse Forums Home Theatre & Automation Re: Ness alarm question 2Aug 26, 2011 10:01 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Ness alarm question 4Aug 29, 2011 4:31 pm Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: Ness alarm question 5Sep 04, 2011 2:39 pm cenemelectrical hello, alot of the time security installers and electricians do not communicate with each other as to positions of security panels etc... which unfortunately sees the end result as above.... i can guarentee that the above pic doesnt have a phone line installed in their aswell! as this is the electricians job ! I would find out asap where the powerpoint and phone line is.. and be quite angry about it due to the lack of communication between trades... what is your builder doing...? this is a major part of their job. hope that helped chris Thank you Chris, Jezza and Pug. When I signed they mentioned the electrician specialises in security system... Anyway there's powerpoint to the alarm box now, but need to check the phone line. Some builders aren't very communicative. Re: Ness alarm question update question help please. 7Sep 19, 2011 6:18 am gelatiii Update, builder says the phone connection is inside the control panel...is what they're telling me the truth? Quite possibly, but if you don't have a beige box at the side of your house marked "Network Terminating Device", then it doesn't comply with regulations. Without a Network Terminating Device, and assuming that your alarm panel has been installed with the appropriate 'mode-3' socket (This allows the alarm to grab the phone line and disconnect the other phones in the house in the event of an alarm) your alarm is the 'first socket'. The regulations require that the home owner is able to access the first socket without the use of a tool. Having the phone connection inside the panel is more secure and is OK as long as there is a Network Terminating Device Paul Re: Ness alarm question update question help please. 8Sep 19, 2011 11:49 am paulw11 gelatiii Update, builder says the phone connection is inside the control panel...is what they're telling me the truth? Quite possibly, but if you don't have a beige box at the side of your house marked "Network Terminating Device", then it doesn't comply with regulations. Without a Network Terminating Device, and assuming that your alarm panel has been installed with the appropriate 'mode-3' socket (This allows the alarm to grab the phone line and disconnect the other phones in the house in the event of an alarm) your alarm is the 'first socket'. The regulations require that the home owner is able to access the first socket without the use of a tool. Having the phone connection inside the panel is more secure and is OK as long as there is a Network Terminating Device Paul Our surburb is FTTP ready, will our provider install the network terminating device? Re: Ness alarm question update question help please. 9Sep 19, 2011 1:22 pm gelatiii Our surburb is FTTP ready, will our provider install the network terminating device? you will need to speak to a cabler.. a NTD isn't inplay with FTTH Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Ness alarm question update question help please. 10Sep 19, 2011 2:00 pm [quote="Pugs" you will need to speak to a cabler.. a NTD isn't inplay with FTTH[/quote] This isn't helping the OP but the Telecommunications Act and S009 still apply to FTTH/FTTP so the provider may elect to install an NTD. The network boundary still needs to be established; This could be an NTD or at the first socket as with traditional PSTN. Paul Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11390 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7336 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12897 |
