Browse Forums Home Theatre & Automation Re: NBN ready - is this a rip off? 22Aug 16, 2011 4:32 pm http://lindeman28.blogspot.com - Our building blog Re: NBN ready - is this a rip off? 25Aug 16, 2011 5:27 pm http://lindeman28.blogspot.com - Our building blog Re: NBN ready - is this a rip off? 32Aug 17, 2011 11:56 pm As someone working on the NBN project atm, I can safely say that you shouldn't go ahead with what they are offering. You can get it much much cheaper than that. NBNCo is responsible for running the fiber from the exchange and terminate at the side of your house. (Not sure where this garage talk is coming from, it doesn't specifically need to be terminated there.) I know already that when it is rolled out in my estate, based on NBN's current guidelines, it will be on the side of my house, external next to my electricity switch. (Opposite side of my house to the garage). There are high chances that where ever your phone line runs into your house, is where the fiber will terminate. As for what they are offering. There will already be a phone point installed with your build so they're giving you an extra data point and a cabinet (that you don't need). My suggestion to "future proof" your home is use that money and run some cat6 cables from where your router will be to your entertainment areas, from there you can expand if you can front the costs. Depending on your needs, wireless may even be sufficient ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: NBN ready - is this a rip off? 33Aug 18, 2011 2:14 pm What you can and can't do is different to what you're licensed to carry out. And your Cisco ticket isn't an open cabling license, i'm pretty sure. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: NBN ready - is this a rip off? 34Aug 20, 2011 12:38 am Firstly $800 dollars seems very reasonable if not cheap, this may be going through builders contract and typically the mark up is a minimum of 30% to cover insurance and put food on the family table ( God Forbid) if so it would cost around $615, I would also say to assume that the Communications cabinet would be empty is also incorrect. To clean up some myths from our forum experts that work with the NBN or are educated enough to be dangerous Green Fields and Brown Fields are different NBN Co uses internal NTD’s for new homes and the Pathway has to be provided by the client/Builder, the NTD and PSU is the property of NBN Co and who ever cables the house is responsible to make sure the internals work, The NTD and PSU must be in a secure location The PDC is were the fibre changes from underground fibre to a internal fibre fly lead. Standard copper phone point is two pair not cat 6 as NBN suggests to use in their documentation Clipsal do make a Cat 6 certified solution, they can’t promote it otherwise, THEY ALSO DO HD NBN is a two layer system, does not carry RF. Telstra Velocity 3 layer carries RF, You need a cablers licence to do internals for NBN like everything else Exposed punch downs do not comply with S2009 http://www.wenban.id.au/HDU.pdf Its all documented, just read it!!! http://www.nbnco.com.au/assets/document ... -guide.pdf NBN ready - is this a rip off? 35Aug 20, 2011 7:58 am I suppose whether the site counts as green field or brown field depends on whether NBN is available the now (or will be at the time the house is completed) or not. From the sounds of the original post, the estate is not currently in an NBN trial site but the builder is offering a NBN readiness package "for the future". When the NBN does reach this house it would probably be treated as brown field. Some conduit will make it easier for them and may cause less disruption, and digging, but they as they need to dig a trench for the Telstra services anyway, they can put conduit in for virtually nothing. Although phone lines only require a single pair and have been traditionally wired with two pair, Telstra currently recommends Cat 5 be used on the customer side of the NTD in order to support future high-bandwidth applications (NBNCo suggests Cat6, which may be a bit excessive, but not too unreasonable given the small cost difference ) The Clipsal Starserve system can carry HD free-to-air channels, but cannot directly distribute in-house HD sources such as Bluray players. Their modulators are composite in/analog out only. you can use third party devices to carry these over cat5/6 - the question is whether the home hub products can justify their price premium over a rack with a patch panel in it. Paul Re: NBN ready - is this a rip off? 36Aug 20, 2011 8:32 am Great to see so much feedback, thanks very much everyone. You assume correct that our estate has not been earmarked for immediate NBN rollout and the package is to be 'NBN ready' for when it does eventually roll around. We have gone with the package and will use the same contractors to provide network points around the house. I assume I will need some kind of a switch or router back in the cabinet. This is probably a really dumb question, but these require power right? I know I'll need one power point for the PSU when NBN comes, bit just wondering how many points I should have the sparkie but in there. Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: NBN ready - is this a rip off? 37Aug 20, 2011 1:58 pm Hi Upnorth, You'll need power for your router (/modem?) Likely to be a 4 port/WiFi My setup has a 12 port patch panel were all the home cat cables terminate http://www.4cabling.com.au/categories/Data-Products/Cat-5E-%26-Cat-6-Patch-Panels/ So need a switch (8 port) which needs power http://www.4cabling.com.au/categories/Switches-%26-Hardware/Ethernet-%26-Network-Switches/10%7B47%7D100%7B47%7D1000-Gigabit-Network-Switches/ We also have a Siemens Gigaset (PSTN/VOIP) wirelsss phone - base station & each handset also needs power. https://www.mynetfone.com.au/Residential/Home-Phone/VoIP-Online-Shop/Wireless-VoIP-Handsets Then also have my NAS located here so it also needs power. We've only got a DPP & have a powerboard for the rest. Most of this gear is only low wattage so shouldn't be a problem. Wouldn't it be great if someone could come up with a single multipurpose powerbox that eliminate all these #$%^& plug packs Got a life, just can't find it! Re: NBN ready - is this a rip off? 38Aug 22, 2011 11:46 am nrh157 We've only got a DPP & have a powerboard for the rest. Most of this gear is only low wattage so shouldn't be a problem. Wouldn't it be great if someone could come up with a single multipurpose powerbox that eliminate all these #$%^& plug packs Sounds like you need a rack with PDU's Re: NBN ready - is this a rip off? 39Aug 22, 2011 5:22 pm I proud to announce that this thread has been nominated for 'thread with most acronyms' award!!!! **head scratch** Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: NBN ready - is this a rip off? 40Aug 22, 2011 5:41 pm Upnorth I proud to announce that this thread has been nominated for 'thread with most acronyms' award!!!! **head scratch** PDU - Power Distribution Unit A power distribution unit (PDU) is a device fitted with multiple appliance outlets designed to distribute electric power, especially to computers and networking equipment located within a data center. http://en.wikipedia.org/wiki/Power_distribution_unit http://imageshack.us/photo/my-images/62/apcpdu.png/ Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15879 I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3148 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9132 |
