Browse Forums Kitchen Corner Re: Pros and Cons on handle-less cabinets/cupboards please 5Aug 12, 2011 12:07 pm Check out our renovation in progress at http://www.ourdiydream.com Follow us on facebook http://www.facebook.com/ourdiydream Check out what we are 'pinning' http://pinterest.com/ourdiydream/ Re: Pros and Cons on handle-less cabinets/cupboards please 6Aug 12, 2011 1:21 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 11Aug 15, 2011 7:28 pm http://lindeman28.blogspot.com - Our building blog Re: Pros and Cons on handle-less cabinets/cupboards please 12Aug 16, 2011 7:31 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 14Aug 16, 2011 9:51 am http://lindeman28.blogspot.com - Our building blog Re: Pros and Cons on handle-less cabinets/cupboards please 15Aug 16, 2011 10:48 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 19Aug 16, 2011 2:00 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 20Aug 16, 2011 2:02 pm silversurfer Amazing looking kitchen, especially like the floating bulkhead over. Are your overhead cupboards full height and pull up or swing doors and do you have magnetic catches on them. They are acutally two cabinets one ontop of the other. The bottom timber grain cabinets are 330mm deep with lift up doors. The top white cabinets are 450mm deep also with lift up handles. There are lights in the bottom of the top cabinets that overhang the timber grain cabinets. (there not on in the photo) No magnetic catches. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12077 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61393 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 |
