Browse Forums Paving & Concreting Re: Cutting the mesh in driveways 6Aug 10, 2011 12:04 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Cutting the mesh in driveways 9Aug 10, 2011 9:27 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Cutting the mesh in driveways 16Aug 14, 2011 10:36 pm As a concrete cutter I can assure you plenty of concreters will cut every second bar in the mesh to force the concrete to crack at that point. This is the point the sawn joint will go over the top. Re: Cutting the mesh in driveways 17Aug 15, 2011 7:42 am Will they also ensure that the saw cut is placed exactly above the line where they cut the wires?? Or, will they cut the wires in a straight line, or will it be a zig-zag job some 50mm off centre?? I guess it all goes back to the workmanship (or the lack of it) My signature is distracting people from my wise posts ... Re: Cutting the mesh in driveways 18Aug 24, 2011 11:21 pm There are three types of joints in concrete: Control Isolation Construction I think. Control joint is what we are talking about. Two ways saw cut or tooled. I tool because hmm I do. I never cut the steel, never needed. Not sure the saw cut would be deep enough to cut the steel, nor should it. Fill the cut with a sealant of sorts. But I guess if you cut steel it will reduce strength, but that must line up with the control joint. No I'm not a concretor, this is what I have done and or seen. Cheers Pulpo Re: Cutting the mesh in driveways 19Sep 04, 2011 9:18 am bashworth ... get a proper designed joint made. Hi Bash, just realised that I didn't quite understand what you meant by this. To get an eng. involved to design the dwy?, or to ask the concretor to do some special joint type, perhaps an isolation joint which goes all the way through (and has abelflex or similar)? Or something else? My signature is distracting people from my wise posts ... Hi, I have had them in the past and the pros are: Versatile, i.e many different colours and styles to choose… 1 7301 MATE!!! I've checked their website and it's a 90% match at least. I've just called them and sent the pic through to confirm it's the same product. Thank you heaps. 3 6685 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11840 |
