Browse Forums Landscape & Garden Design Re: Our Landscaping Story 142Jun 16, 2011 8:19 pm 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Our Landscaping Story 144Jun 16, 2011 8:56 pm 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Our Landscaping Story 145Jul 31, 2011 8:38 pm Our deck extension project has slowed considerably over the past little while, due to weather and better things to do etc. 6 weeks ago I bought some paint for the wall and immediately applied the sealer undercoat, but it was only today that I applied the medium texture render finish. It will be further coated in our chosen colour, Colorbond Deep Ocean, to match the trims on the house. Hopefully this will happen tomorrow. Then, all I have to do is clean and oil the deck extension, arrange the water feature and some furniture there, and whack some gardens in along each side. I still haven't really made up my mind what to plant; my latest idea is to maybe have some sort of vine grow along some stainless steel wires or something. Grapes, maybe? The wall, firstly after undercoat, and secondly after 2 coats of Dulux medium texture, finished with a sponge wipe. The hole is for the lead for the water feature and the light patches are reflected light from the windows on the house. Geoff - Decophile. Re: Our Landscaping Story 146Jul 31, 2011 8:44 pm Wall looks great already. How did you find the render to use? We were reading the backs of the tins today wondering whether it's the right thing to use on our concrete letterbox. Re: Our Landscaping Story 147Jul 31, 2011 9:26 pm Ohhh, catjim, if only I knew what I didn’t knew! I got some advice on how to apply this particular type of paint, and had the correct type of roller (it looks like it is made from the hook part of Velcro, only longer). I was told to paint several strips then go back and finish with overlapping downstrokes to make sure all the little bumps faced the same way, to make sure it all looked even, while that section was still wet. I applied the first coat, from the right hand side of the wall, and everything went very well until the last metre. For some reason the roller started to become bogged and it was skidding across the surface instead of rolling. Nevertheless I finished with the downstrokes there but it appeared patchy. So, I downstroked the entire wall but I then ended up with tell-tale vertical stripes all over! Arrrggghhhh!!!!! So much for trying to get away with one coat! By the way, the advice was that 10 litres of medium texture might have been barely enough anyway (area of the wall is a little over 10 square metres) but I had only used half....hmmm. So I proceeded with a second coat. It quickly became obvious that I was going to run out of paint! I started to dilute it down, and experimented with finishing it off by wiping the wet paint with a sponge (which was the finishing method that was written on the tin!). That worked very well and I’m now spewin’ that I didn’t try that with the first coat! Anyway, by the last square metre I was virtually out of paint, and I was actually applying it with the sponge. Now, I was spewin’ that I didn’t apply it that way to begin with!!!!! The very left hand part of the wall does look a bit rougher than the rest, but it should come up alright still I think. Geoff - Decophile. Re: Our Landscaping Story 148Jul 31, 2011 9:37 pm Oh gosh, it doesn't sound easy. We've got two rendered portico posts in paperbark and we'd like to do the letterbox to match. Might have to do a bit of experimenting first. Re: Our Landscaping Story 149Jul 31, 2011 9:44 pm No, have ago at it! If you are only doing narrow areas, it will be easy. It’s only because I was painting such a wide area that it was always going to be a bit d0dgy how the transition to the ‘wet line’ was going to end up. Geoff - Decophile. Re: Our Landscaping Story 150Jul 31, 2011 10:10 pm Good stuff Eager!! This time of year hasn't been very good for outdoor projects 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Our Landscaping Story 151Aug 01, 2011 10:16 am You're not wrong! Even getting the deck built in Autumn was bad because it was way wetter than usual. But at least it should all be done in time for the warmer months, so we can actually get out there and enjoy it! Geoff - Decophile. Re: Our Landscaping Story 152Aug 01, 2011 7:50 pm More progress! After waiting forever today for yesterday’s second render coat to dry , I applied a coat of Deep Ocean. It went on well and at a glance it looks excellent, but what I found when I stepped back is that a dark colour shows up more imperfections than a light finish. I might just let it pass. The bold colour looks great against the timber though, and has the desired effect of matching the trims on the house: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The other thing I did today was to buy some heavy gauge perforated sheet metal from a local industry and cut it to shape to be used in my water feature as a tray to hold pebbles. This is for two purposes; firstly to make it look a whole lot more attractive including hiding the inlet hose from the pump, and secondly to quieten down the splashing noise from the water falling back into the trough: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Geoff - Decophile. Re: Our Landscaping Story 153Aug 01, 2011 7:55 pm Looks great Geoff! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Our Landscaping Story 157Aug 01, 2011 9:45 pm Absolutely love your work. Like how you have thought about all the details for your water feature. 26/2 - Sales 23/3 - Colours 31/3 - Tender 14/4 - Contract 7/5 - Taps 12/6 - Site start 15/6 - Slab 27/6 - Frame 1/8 - Lockup/Fixing 29/9 - PCI 25/10 - Handover Re: Our Landscaping Story 158Aug 02, 2011 10:16 pm love it. cant wait to see it finished Harrisdale backyard finally done! Re: Our Landscaping Story 159Aug 03, 2011 11:18 am Thanks for sharing - looks great! Lots of useful info here ... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Our Landscaping Story 160Aug 03, 2011 7:29 pm Thanks, everyone! Also discovered today that a brick standing on its end is the absolutely perfect size to support the pebble tray in the water feature (it was only just balancing there before and would have fallen in with any weight on it). DW suggested it. I doubted her. I'll never learn. Geoff - Decophile. Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8373 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4042 Hmmm, I have checked your past posts and it seems that you are in NSW, not WA as I had thought. It pays to show your State in your avatar. Retaining wall regulations… 5 7845 |
