Browse Forums Kitchen Corner Re: Laminex DiamondGloss Edging question 9Jul 23, 2011 8:23 am Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: Laminex DiamondGloss Edging question 10Jul 23, 2011 8:23 am Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: Laminex DiamondGloss Edging question 11Jul 23, 2011 8:49 am The edging is great, only problem is on a waterfall island unit. The edging doesnt cause a problem its the laminate. The bench top and waterfall are usually joined at 45degrees casuing a very sharp edge that is easily damaged. Butting the waterfall up under the bench top is a solution but doesnt look that great. Does anyone have pictures of a 45degree laminate join on a waterfall that is a few years old? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Caesarstone, quantum zero, Q Stone zero, porcelain. All the manufacturers are pivoting into zero silica materials. Google any of those and have a look. Some are still… 1 599 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9980 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 |
