Browse Forums General Discussion Re: cracking between floor boards- is this normal 30Jul 21, 2011 4:34 pm Yep, clumps and then a gap ... I am a bit surprised to hear of such quite serious case of edge bonding with Traffic!! Anyway. What did they use as "fill"? The type of material can make a difference in how well it stays put. I'm glad that they didn't rush and resand your floor this soon. It's better to let the floor go through at least 1 full year (even more) and then "attack" it if it's still that bad. Although, if they "played" with some spot filling, perhaps won't be a bad idea to make it all the same again, but probably without any coarser sanding, just enough to recoat. My signature is distracting people from my wise posts ... Re: cracking between floor boards- is this normal 32Jul 21, 2011 8:04 pm Timbermate is great. But, as the boards keep moving in the future, it will crack and some of it will get out of the gaps (eventually). It's not that great to fill the actual gaps between the boards (because of the movement). However, it's not as bad as it sounds. It's just a floor and unless everything on and above that floor is absolutely sleek and spotless, this small imprefection should not matter (although it can be very annoying to look at it every day! ). Most of the time guests won't notice it at all, it's only us, the owners, who will constantly keep looking at all those many "eyesores" and get stressed My signature is distracting people from my wise posts ... Re: cracking between floor boards- is this normal 33Jul 22, 2011 1:58 pm Sorry donnam, I'm not going to offer any advice as I have no idea why it's happening. But I will offer up our experience & say that prior to installing our Sydney Bluegum floorboards in our previous house, we were advised by the timber supplier against using polyurethane because the floorboards were likely to split. We went with tung oil instead. My 1 cent worth anyhoo Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: cracking between floor boards- is this normal 34Jul 23, 2011 10:19 pm Lex whilst most people won't notice our floor it is quite noticeable walking around in bare feet. The cracks (there's a lot of them) are quite rough Southies- can you tell me more about tung oil. The floor guy the other day was not giving it a good rap at all. How did it hold up and how was the maintainance? Ta Donna Re: cracking between floor boards- is this normal 36Jul 24, 2011 9:59 am donnam Southies- can you tell me more about tung oil. The floor guy the other day was not giving it a good rap at all. How did it hold up and how was the maintainance? Well I am soooo surprised by his comment ! We loved it. Maybe he should have been more specific about why he wasn't happy with it We opted against p/u because of the 'splitting' issue & particularly because of the need to RE-SAND & RE-POLISH after a few years $$$$$ We had the flooring in our family room which was under daily attack by 3 primary-aged kidlets. We certainly wanted something that would withstand that kind of punishment. With tung oil, the high traffic areas just got duller & duller over time, though no scratches. It meant that we needed to apply tung oil to those areas every year to bring out the shine, again. But this was a matter of only dipping a string mop in a bucket of tung oil & slopping it on the required areas - 1 hour to dry & VOILA! a new floor. Just like washing the floor. We certainly did not need to do the entire floored area, just where it was required. Very easy process & certainly cheaper a totally stressless as opposed to re-sanding & re-polishing the entire area I would DEFINITELY use tung oil again, if given the choice. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: cracking between floor boards- is this normal 37Jul 24, 2011 12:28 pm Wow, that's certainly good to hear, Southies!! We were strongly swayed away from using oil-type of coatings. We were told that they will show your foot prints (I guess if you walked bare-foot, which we actually never do), and that it would remain oily for quite some time and a nuisance to upkeep as every year we'd have to remove all the furiture in order to re-apply it, etc, etc, heaps of negative stuff. Obviously, solvent-based P/U is a no-no for new floors ... so we went with water based ... Anyway, my stairs are nothing like these guys told me it would be. In fact, they look as if there is a shiny thick coat of P/U!! But I'm pretty sure that it is indeed tung oil. Which would be great so that I can rejuvenate them where needed (although with stairs, it would be easier to re-apply to the whole step, not just where it's worn out). My signature is distracting people from my wise posts ... Re: cracking between floor boards- is this normal 38Jul 24, 2011 1:02 pm Lex We were told that they will show your foot prints (I guess if you walked bare-foot, which we actually never do), and that it would remain oily for quite some time and a nuisance to upkeep as every year we'd have to remove all the furiture in order to re-apply it, etc, etc, heaps of negative stuff. Quote: Anyway, my stairs are nothing like these guys told me it would be. In fact, they look as if there is a shiny thick coat of P/U!! Quote: Which would be great so that I can rejuvenate them where needed Built the Eden Brae Cambridge 34 Family with Boston Corner Facade To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 969 Yes, get a builder, make sure he is experienced and a registered building practitioner 5 9182 |
