Browse Forums Bathrooms and Laundry Re: Strange dark areas in sealant near shower base? 2Jul 21, 2011 11:00 am Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Strange dark areas in sealant near shower base? 4Jul 21, 2011 4:22 pm Agree with Dee unfortunately it's mould!! In the last house this happened all the time, even though the exhaust fan was used for every shower and didn't matter if a mould-resistant silicone was used it still reappeared. Bleach applied with an old toothbrush and left for half an hour before showering would do the trick, albeit temporarily. Window in the ensuite was open all day, closed at night, but it seemed that the base of the shower, especially in the bottom corners wasn't getting enough air flow because it didn't happen through summer. I dislike using silicone for this reason and fortunately the shower screen installers for the new house were in agreeance and said they never use it except where it will not be visible, such as under framing etc. Tilers just used regular grout and (fingers crossed) it's been OK so far but this is only the first winter and on wet days the bathroom windows can't be opened at all because they are on the south side and rain blows in. Not sure this helps much? Re: Strange dark areas in sealant near shower base? 5Jul 22, 2011 3:42 pm ^ITA! Water always seems to get under the silicone & the "anti mould" ones are a crock. You still get mould. I always prefer grout between tile lines wherever possible. If you're going to the effort of removing the silicone maybe grout it instead. Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 12607 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10902 I have seen poly marble shower bases last in excess of 30 years 1 4546 |
