Browse Forums Kitchen Corner Re: laminate countertop enquiry 4Jul 15, 2011 9:13 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: laminate countertop enquiry 6Jul 15, 2011 10:03 am CuttingEdgeKitchens From what it sounds like they have installed square edge laminate tops. These should never be used in a kitchen. The square edge allows moisture into the board which then swells and expands the board and edge. Thanks for your reply, Could you provide me with a refernce or link forthat advise to use it if needed? Re: laminate countertop enquiry 7Jul 15, 2011 7:14 pm hoba CuttingEdgeKitchens From what it sounds like they have installed square edge laminate tops. These should never be used in a kitchen. The square edge allows moisture into the board which then swells and expands the board and edge. Thanks for your reply, Could you provide me with a refernce or link forthat advise to use it if needed? Sure no problems at all. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 7535 We are doing heaps of hybrid at the moment and the cost sits between $60-65/sqm including installation. Stairs are around $90-100 each 1 4701 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 5408 |
