Browse Forums Bathrooms and Laundry Re: 2 shower heads 11Jun 27, 2011 9:02 pm . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: 2 shower heads 12Jun 28, 2011 11:05 am Doh, bit late to the ball game. If you want to spend about 9k, then the kohler thermastatic mixer and control pannel would probably do what you want to do (and more) though if you were spending that kind of money, id go the whole kit and kaboodle and get the wall/ceiling jets from the DTV package too.... *drool* (not into the light show and aromatherapy myself) http://au.kohler.com/products/showering-technology.aspx our budget only went as far as the water tile shower head Re: 2 shower heads 13Jun 28, 2011 1:11 pm I'm a bit late too but here goes........ In our old house we had an instant heat hot water service with controllers to set the temp that you want. If you were in the shower and someone elsewhere in the house turned on a hot tap the pressure dropped. If they turned on a cold tap there was no difference in the shower. This was because you only needed to turn on the hot tap in the shower. No fiddling around with mixing hot and cold water to get the right temperature. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5841 Ask yourself if the insurance company will be aware of the Reno. 4 7370 |
