Browse Forums Building Standards; Getting It Right! Re: 60mm Overhang On Bricks? 5Jun 19, 2011 6:01 pm Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: 60mm Overhang On Bricks? 16Jun 26, 2011 11:35 am Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: 60mm Overhang On Bricks? 17Jun 26, 2011 1:27 pm The carpenter got a piece of treated timber he placed it under the bricks, they then painted it paperbark to match. They have done a good job, you can't even tell it's been done now. My Son's boss was going to send his renderer over to render it, but we opted for the timber. Make sure you get it fixed as it's not a good look. I ddin't want that showing at the front of the house. Re: 60mm Overhang On Bricks? 19Jun 26, 2011 2:14 pm adgn Chorlton I ask as the brickwork over our Garage overhangs the edge of the lintel by around 35-40mm and apart from it looking unsightly and poorly finished, our concern is that only around 2/3rds of the width of the bricks are being supported. Chorlton Hey Chorlton, What brick colour is that? Looks like the Austral impressions range.. Its from the Boral range - Murrey River TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: 60mm Overhang On Bricks? 20Jun 26, 2011 2:17 pm deb17 The carpenter got a piece of treated timber he placed it under the bricks, they then painted it paperbark to match. They have done a good job, you can't even tell it's been done now. My Son's boss was going to send his renderer over to render it, but we opted for the timber. Make sure you get it fixed as it's not a good look. I ddin't want that showing at the front of the house. Hi Deb, I was actually thinking of suggesting this as a solution but wasn't sure if it was that sensible a suggestion. However, if its already been done and the final execution looks good, then I will definately suggest it. Thanks for the Reply, All the best, Chorlton TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7867 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3852 |
