Browse Forums Heating, Cooling & Insulation Re: How to size ac's for 6 star homes? 2Feb 15, 2011 3:16 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to size ac's for 6 star homes? 8Jun 15, 2011 1:17 am . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: How to size ac's for 6 star homes? 14Jun 24, 2011 9:19 pm The house is having R4.1 in the ceiling and R3.0 in the walls...not sure if its getting foil though...the builder is higher end so expect it will have foil. Decided to go with the 7.1 KW system upstairs for the moment, they've recommended Daikin, i know they're suppose to be good but they don't seem to have all the features on the indoor head unit the panasonics/mitsubishi's have...have two split mitsubishi's over ten years old with no problems so i'm assuming reliability with these things isn't really a problem. There are two rooms on two levels to be air-conditioned, seen that Mitsubishi make systems capable of having multiple heads put on, are these very good? Or better off with two completely separate systems... The house will only really be used for maybe 4 weeks of the year but that usually includes some of the hotter periods just after christmas or again when Adelaide has a heat wave...that and the opposite in middle of winter...so the true extremes really... 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 2263 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3830 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3743 |
