Browse Forums Building A New House Re: Need info on making 20ft by 20ft gym 6Jun 22, 2008 12:33 am mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Need info on making 20ft by 20ft gym 8Jun 22, 2008 6:36 pm Dukekamaya Definately will require approval, I took that as assumed Just makin' sure.... sounds like it will be a family project. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Need info on making 20ft by 20ft gym 9Jun 22, 2008 6:38 pm to_do_list Dukekamaya Definately will require approval, I took that as assumed Just makin' sure.... sounds like it will be a family project. Ok before the days of Google Earth Paula Re: Need info on making 20ft by 20ft gym 10Jun 22, 2008 6:55 pm Shed approvals differ from council to council. My local council will allow you to erect a shed no more than 12 sq. metres and no more than 2.4m high without approval which isn't too bad I think. Re: Need info on making 20ft by 20ft gym 11Jun 22, 2008 7:35 pm Dukekamaya Shed approvals differ from council to council. My local council will allow you to erect a shed no more than 12 sq. metres and no more than 2.4m high without approval which isn't too bad I think. Same as our council.....Jacked's Gym is about 36 sq.m though.....Paula's right council will find you out using Google Earth and their own imaging that they do. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Need info on making 20ft by 20ft gym 12Jun 23, 2008 1:17 pm to_do_list .Paula's right council will find you out using Google Earth and their own imaging that they do. this depends where you are located from everything i researched on it...though if you know more can you share? Re: Need info on making 20ft by 20ft gym 13Jun 23, 2008 1:34 pm stewy to_do_list .Paula's right council will find you out using Google Earth and their own imaging that they do. this depends where you are located from everything i researched on it...though if you know more can you share? In Victoria, Councils can purchase high resolution imagery from the Department of Sustainability - so high resolution (15cm x 15 cm) that on the image of our old house I could see the washing on the line.... ..... - this imagery can be used to increase your rates due to "land value improvements" or to check on illegal building. The councils sign up to a Comprehensive Imagery Program and can split the costs of image capture. Our organisation recently needed some imagery for western Melbourne - the area had already been flown by Wyndham Council for planning purposes - so we had to share costs with Wyndham. Property checks ares probably random therefore it's a roll of the dice thing....but it doesn't even have to be this high tech....what if your neighbour doesn't like what your building a reports it to council? There have been some urban myths around using the same sort of imagery for water tanks but I think that is just a myth..... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6641 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 2957 Yes, Im following your Lindfield build, looks amazing. 4 2660 |
