Browse Forums Building Standards; Getting It Right! Re: 60mm Overhang On Bricks? 5Jun 19, 2011 6:01 pm Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: 60mm Overhang On Bricks? 11Jun 22, 2011 1:44 pm The site supervisor has said that the are going to drill into the existing slab and add another slab underneath it and give us an extension onto our patio (because its not really a structural wall should i still ask for an engineers report?) As far as termite protection goes cause of the cavities straight up the bricks i've asked for more termite protection. Re: 60mm Overhang On Bricks? 13Jun 22, 2011 7:27 pm The bricks over our garage were the same, it's not a good look, our builder fixed the problem, by adding to the lintel. It wasn't as much as yours is though and only to the front of the house over the garage. I would be asking for it to be fixed properly, it's just not right. Re: 60mm Overhang On Bricks? 14Jun 22, 2011 8:20 pm he only way to fix this is to drill lots of holes along the side and insert dowels all the way. Then poor concert into it. Although this method is very difficult once the bricks are already up. Re: 60mm Overhang On Bricks? 15Jun 26, 2011 10:11 am deb17 The bricks over our garage were the same, it's not a good look, our builder fixed the problem, by adding to the lintel. It wasn't as much as yours is though and only to the front of the house over the garage. I would be asking for it to be fixed properly, it's just not right. Hi Debs, How did your builder fix the problem? I ask as the brickwork over our Garage overhangs the edge of the lintel by around 35-40mm and apart from it looking unsightly and poorly finished, our concern is that only around 2/3rds of the width of the bricks are being supported. http://i1091.photobucket.com/albums/i389/chorlton001/House%20Build%20Issues/IMG_4138.jpg Any advice appreciated.... Thanks, Chorlton TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: 60mm Overhang On Bricks? 16Jun 26, 2011 11:35 am Chorlton I ask as the brickwork over our Garage overhangs the edge of the lintel by around 35-40mm and apart from it looking unsightly and poorly finished, our concern is that only around 2/3rds of the width of the bricks are being supported. Chorlton Hey Chorlton, What brick colour is that? Looks like the Austral impressions range.. Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: 60mm Overhang On Bricks? 17Jun 26, 2011 1:27 pm The carpenter got a piece of treated timber he placed it under the bricks, they then painted it paperbark to match. They have done a good job, you can't even tell it's been done now. My Son's boss was going to send his renderer over to render it, but we opted for the timber. Make sure you get it fixed as it's not a good look. I ddin't want that showing at the front of the house. Re: 60mm Overhang On Bricks? 19Jun 26, 2011 2:14 pm adgn Chorlton I ask as the brickwork over our Garage overhangs the edge of the lintel by around 35-40mm and apart from it looking unsightly and poorly finished, our concern is that only around 2/3rds of the width of the bricks are being supported. Chorlton Hey Chorlton, What brick colour is that? Looks like the Austral impressions range.. Its from the Boral range - Murrey River TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: 60mm Overhang On Bricks? 20Jun 26, 2011 2:17 pm deb17 The carpenter got a piece of treated timber he placed it under the bricks, they then painted it paperbark to match. They have done a good job, you can't even tell it's been done now. My Son's boss was going to send his renderer over to render it, but we opted for the timber. Make sure you get it fixed as it's not a good look. I ddin't want that showing at the front of the house. Hi Deb, I was actually thinking of suggesting this as a solution but wasn't sure if it was that sensible a suggestion. However, if its already been done and the final execution looks good, then I will definately suggest it. Thanks for the Reply, All the best, Chorlton TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7745 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3793 |
