Browse Forums Kitchen Corner 1 Jun 17, 2011 2:46 pm hi, guys, I just moved into a new place (renting, and my first foray out of the family home), and bought a washing machine before realising there's no place to put it(!). Rather than let it gather dust, I was hoping to rig it to the kitchen faucet/sink. Being completely ignorant on the matter, does anyone have any suggestions/experience about how/whether this is possible? I'd popped into my local plumbing store and they suggested that the pressure from the machine would likely blow the faucet, and I had a quick peek under the sink and see no pipes to rig up any plumbing (i.e. it's all behind the tiles). I'll post up an image shortly, but appreciate any advice! Mthks Re: Washing machine to run off kitcken faucet? 3Jul 07, 2011 1:00 pm ack_84 *bump* mods, might you consider moving this thread to the "bathroom & laundry" forum? thnx You might be best calling a plumber to see if its possible. If it is possible you will need the plumber to make the conection anyway! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Washing machine to run off kitcken faucet? 4Jul 07, 2011 1:10 pm A few years ago when I was living in a unit I had a front loading washing machine on castors that ran off the kitchen tap. My plumbing supplier provided me with a special fitting that replaced the existing end cap of the tap and a matching piece for the washing machine hose so that the two clicked together much like an air hose - never had a problem with it except for a tendency for the washing machine to try and roll away if we forgot to lock the castors. Cheers, Earl Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17879 7 6357 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 9067 |
