Browse Forums Landscape & Garden Design Re: SOAKWELLS - How easy are they to put in and install ? 107Jun 12, 2011 9:48 pm The crate ones from soakwell solutions are good too. Just weigh up the budget and what you need for the money. Re: SOAKWELLS - How easy are they to put in and install ? 108Jul 06, 2011 12:38 am DIY SOAKWELL INSTALL: viewtopic.php?f=31&t=48722 Fu, any chance of a sticky. Its currently int the building a new house section, not sure if it should be in the landscaping area. Re: SOAKWELLS - How easy are they to put in and install ? 109Jul 22, 2011 9:34 am Fu Manchu One standard roll of 90mm ag pipe is the equivalent to 1 and a bit soak wells for drainage. Fu, what do you mean by this?? (And how long is the standard roll of 90mm ag pipe?) My signature is distracting people from my wise posts ... Re: SOAKWELLS - How easy are they to put in and install ? 110Jul 22, 2011 10:02 am Fu Manchu No only the ag drain. One agdrain will do more than a concrete soak well ;)If you link all the ag drains as I have suggested in a few posts on this then the efficiency of the drainage is pretty good and will handle almost anything thrown at it. The reason being that not all your drain pipes will flow the same volume of water. So if they are all linked, the area for water to soak away is massive. Have the drain pipe empty into a grate then into the ag drain. If the ag drain or soakwell plumbing is directly connected to the drain pipe, your eves and even home can be flooded. Also sand can be forced up through paving from the soakwell. If the two are separated when the drainage fills water can still be drained from the roof and the water will flow out onto the paving. Even in the heavy rain we had in Perth the other day water drained away at a massive rate. Water pressure forms in heavy rain to cause this when the whole lot backs up. With homes connected to storm water the pipe needs to be directly connected to the stormwater. As I understand, this thread only deals with soakwells for roof rainwater run-off?? What about water that collects behind retaining walls? How is the volume of that water calculated? We'll have some 8m3 of soil to drain from behind the walls. Could we get away with just some ag pipes to drain that area, or do we still need some absorption pit?? My signature is distracting people from my wise posts ... Re: Re: SOAKWELLS - How easy are they to put in and install 111Jul 22, 2011 4:58 pm Is this established or are you doing this before turf etc goes down? Re: SOAKWELLS - How easy are they to put in and install ? 113Aug 20, 2011 9:46 pm Hi Fu/everyone.... Been reading this entire thread with interest because we need to look at installing some sort of system to capture our rain/stormwater. Thing is, we are in Melbourne so not sure what products are available here but that's another question. My question is... with regards those plastic cubes (the first ones you recommended from Global Synthetics)... on their website that you provided the link to... it says that they are 'stacked into a matrix of cells to create the desired storage volume'. So I was of the understanding that perhaps you connected all your downpipes to one point (or two - or whatever) and then funnelled those one or two pipes into the one 'matrix of cells'. But it seems that you recommend one separate cell per down pipe? We currently have our downpipes connected to pvc piping that flows into what might be considered an ancient type of soak pit (a small bricked 'well' type of thing) which we found under our deck. About 3 or 4 downpipes on one side of the house are all connected to one pipe and flow in to one side of this 'pit' and about 2 or 3 downpipes on the other side of the house are connected and flow in to the other side. It all collects in this 'contraption' and then all flows out of that into an old terracotta pipe that leads to nowhere in the middle of our back yard. However with any decent rain, it isn't adequate and our backyard gets sodden as well as under our deck and under our entire house getting overflowed from this small inadequate collection point. We didn't have anything to do with this system, we just inherited it (yay!). Our backyard is currently half dug up due to trying to figure out what was happening with our drainage and now that we've gotten to the bottom of that, the next thing is to rectify it and make our drainage for more capable of dealing with heavy rain. It is our very next priority and hope to spend tomorrow formulating a plan. But essentially, I am wondering if the two pipes that collect the water from all the downpipes and lead into this ancient soak pit contraption could still be left 'as is' but instead of going off into a terracotta pipe to nowhere, redirected to a 'matrix' of these cells out in the yard - or under the deck (where the current pit thing is. Or..... do we need to put one cell in at each downpipe point as you seem to suggest in all the other posts? Thing with that is, most of our downpipes are just into soil/garden - not paving. But one or two are under already under the concrete driveway so difficult to put a cell in there for eg. And I'm not feeling overly confident with the notion of just having the downpipe separate from the grate or whatever. We already have issues with damp around our house, and the last thing I need is for water to rush out of downpipes and flow into soil around the house creating more damp. I really need ALL water collected and 'dealt with' even if we have to put in extra pipes or cells or agi pipe or whatever it is we choose for us. Anyway,hope my explanation is clear so that you can understand my question. Any thoughts?? HHCIB Re: Re: SOAKWELLS - How easy are they to put in and install 114Aug 21, 2011 8:23 pm Link it all into one. They used to have a great shot on the website where they adapted these drainage cubes into a huge underground water storage tank. Essentially using a massive liner, a geotextile, a heap of cubes stacked for integral strength and the back filled it became an underground water tank. Feel free to email them about the details of what they did. They have been a big help to me over the years. Also PM Bradtez here on the forum or go to the link for his business. He maybe a help also. Re: Re: SOAKWELLS - How easy are they to put in and install 115Aug 22, 2011 1:06 am I'm no expert but I would check the soil in the pit and see if the top layer needs removed to make water entering it enter the ground better. I would then replace the terracotta with pvc cause terracotta is not fantastic against root attacks between the cemented joins. I would have the pipe sloped so water flow away from the house direction. From there I would install the soakwell of your choice at the end of where the terracotta use to end.. Re: SOAKWELLS - How easy are they to put in and install ? 116Aug 25, 2011 9:45 pm Thanks duke... that all sounds very reasonable. Might keep that as an option - we are still weighing up all of our options. Thanks Fu... I hope you don't mind, I have PM'd you. HHCIB Re: SOAKWELLS - How easy are they to put in and install ? 117Oct 08, 2011 5:34 pm Fu and/or others. Thank God for sites like these and Googs I am about to build a small home on a small block in the Dawseville area WA and guess what the good old reliable Council have changed the rules on the siting of Soakwells. They used to have to be 2M from any structure but now it seems its 4M and this I cannot do. So whilst my existing plans show a 1500x1200 and a 1200x1200 for 9 downpipes off a 200m2 roof area at a PS of $4,000 they now advise they need to go to fully blown Engineering Drawings to overcome this horrendous development at a very realistic cost of $900 plus. What Crap. So I have been reading these threads to find a solution. Am I correct in assuming that the use of 90mm Agri Pipe of suitable lengths connected by Poly Pipe to say 3 Down Pipes is a satisfactory solution given that my set backs are 1M on the side and 2M to the rear plus the required Open Space??? Or is there a better combination. Any assistance/advice welcomed as would be capable trades in the Mandurah area. House Trained Re: Re: SOAKWELLS - How easy are they to put in and install 118Oct 09, 2011 1:58 pm that's like my lot. They basically interconnected all the downpipes' polypipes and brought it to the front (which has the most open space) and put soakwells of your choice and size. Re: SOAKWELLS - How easy are they to put in and install ? 119Nov 19, 2011 12:07 pm house trained Fu and/or others. Thank God for sites like these and Googs I am about to build a small home on a small block in the Dawseville area WA and guess what the good old reliable Council have changed the rules on the siting of Soakwells. They used to have to be 2M from any structure but now it seems its 4M and this I cannot do. So whilst my existing plans show a 1500x1200 and a 1200x1200 for 9 downpipes off a 200m2 roof area at a PS of $4,000 they now advise they need to go to fully blown Engineering Drawings to overcome this horrendous development at a very realistic cost of $900 plus. What Crap. So I have been reading these threads to find a solution. Am I correct in assuming that the use of 90mm Agri Pipe of suitable lengths connected by Poly Pipe to say 3 Down Pipes is a satisfactory solution given that my set backs are 1M on the side and 2M to the rear plus the required Open Space??? Or is there a better combination. Any assistance/advice welcomed as would be capable trades in the Mandurah area. House Trained If they are saying a soak well must be 4m from a home then, the ag drain won't be able to be used either. You will need to use 90 or 100mm (use 100mm if you can) between each outlet of the down pipe and then direct all of them to a central drainage point that is more than 4m form the home, such as a small front court yard or similar. DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 41546 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8640 0 9818 |
