Easy, just say "hun, I'm popping out, will be back soon. I'll pick up a bottle of red on the way back".
..... Oh it's only 2 sleeps till Saturday.
Browse Forums Building A New House Re: Porter Davis homes 2281Jun 09, 2011 1:40 pm Ivanhoe 36 Dep:18-4-11 Tender:26-5-11 Colour/Electrical:8-6-11 Contract:29-6-11 Building Permit:6-7-11 Site Start:16-8-11 PCI:10-1-12 Handover:24-1-12 http://eli-kay-ivanhoe36.blogspot.com/ Re: Porter Davis homes 2286Jun 09, 2011 2:33 pm Hi Chorlton I have not started building yet but was just looking at my plans when I read your post. My plans indicate that the back wall and the wall joining the hallway have plaster - but the external wall (closest to the fence) does not. Which sounds the opposite of what you have....so not much help! Re: Porter Davis homes 2287Jun 09, 2011 2:39 pm Chorlton INTERNAL FINISH OF THE GARAGE Hello All, For all those who have now built with PD, may I ask what the internal finish was inside your garage? If it has been lined with plaster board sheets were all sides of the garage boarded? I ask, as in my garage all sides have been plaster boarded with the exception of the (i) front wall (either side of the garage door) and more strangely (ii) half of the back wall in the area of the rear garage door. When I asked my SS why the rear wall had not been completely plaster boarded, I was told that was the actual finish for a PD home and that all PD's homes are constructed in a similar way ??!!??? Personally, it nots very aesthetically pleasing and looks basically unfinished, and consequently would welcome others comments on this before I raise the issue again. Thanks in advance, Chorlton I learnt something new today.. Checked my plans and same deal here, plaster on the back wall only. Re: Porter Davis homes 2288Jun 09, 2011 2:57 pm According to my plans, there is a note in the garage area which says "timber framed walls with plasterboard lining both sides" with an arrow pointing towards the two internal walls. However, I assumed (lesson here for everyone!!!) that the rear wall which is half timber frame and half brickwork only would have plasterboard on all of it and not just the bit that is timber framed. Personally, IMO its not 100% clear and making a reasonable assumption you would expect that the whole wall would be done the same. What is also strange is that there are no notes that actually refer to plasterboard on the garage external side wall (which is obviously just brick). However, I have plasterboard there !!!!!!!????!!!! So, even if you read the plans correctly, what I have in my garage is different......... The result is that I now have an area of around 2m around my rear garage door with just brickwork whilst both sides of the walls have plasterboard. To say it looks stupid is an understatement !! TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: Porter Davis homes 2292Jun 09, 2011 3:08 pm To be quite honest I haven't even had a good look at the garage, I know some is plaster and some isn't, and to be perfectly honest I don't even care what the garage looks like I'll park my car and go to the kitchen LMAO Alot of our garage walls will be covered by tools and storage shelves... My building thread : viewtopic.php?f=31&t=36059 Paid initial deposit 24/7/10 Tender appointment 20/8/2010 Flooring and tile appointment 25/9/10 Colour and Electrical appointment 13/9/10 December site start delayed Site start (YAY!) 17/1/11 Slab pour 1/2/2011 Re: Porter Davis homes 2293Jun 09, 2011 3:10 pm I also don't mind having the exposed brick in places - it is easier to hang things from. However, what Chorlton is saying sounds silly - a half and half wall!!?!?!?! It also doesn't match the plans - so that should help the arguement with PD surely? Re: Porter Davis homes 2294Jun 09, 2011 3:12 pm tstr1a Chorlton post a pic of your garage plan so we can all see. Cheers I'll try to do it later today..... BTW: Wall between House and Garage is mostly just timber. TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: Porter Davis homes 2295Jun 09, 2011 3:13 pm Chorlton tstr1a Chorlton post a pic of your garage plan so we can all see. Cheers I'll try to do it later today..... BTW: Wall between House and Garage is mostly just timber. Love to see you build in progress, do you have a thread or a blog? Re: Porter Davis homes 2296Jun 09, 2011 3:19 pm building1 To be quite honest I haven't even had a good look at the garage, I know some is plaster and some isn't, and to be perfectly honest I don't even care what the garage looks like I'll park my car and go to the kitchen LMAO Alot of our garage walls will be covered by tools and storage shelves... I accept your point and in the grand scheme of things its not that important. However, like a lot of building related things if it looks right it probably is and if it doesn't then it stands out and people question it. Having an area of no more than 2m brickwork and the rest plasterboard looks basically unfinished and is clearly visible when the garage door is open. If they had built it as per the plans then the external garage side wall would also be brickwork and as a result would be a lot less noticable. Am I going to ask PD to remove the plasterboard which is wrongly fitted? Of course not, but at the same time the current finish looks strange IMO. PS. Tstra1a..... No blog unfortunately as I just haven't had the time to create and update one. But I will try to sort out some pics for those interested......... TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: Porter Davis homes 2297Jun 09, 2011 3:20 pm Hi, I just looked at my plans & have the plasterboards throughout the rear wall only as attached. I thought the entire garage would cover up with the plasterboards. Learning to study the final drawings at the later stage... [img][IMG]http://img845.imageshack.us/img845/7006/garagewall.jpg[/img][/img] Re: Porter Davis homes 2298Jun 09, 2011 3:30 pm Hi, On our plans it shows that only 2 walls are to be plastered. Those walls are the internal walls, which are the laundry wall and entry wall for us, though they have plasterd all of the garage and have left a little exposed brick around the rear access garage door. take a look on my thread. Page 10 there is a pic of the facade where you can see the inside of our garage. Building the Porter Davis Sandhurst 33 Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=42820&start=20 Re: Porter Davis homes 2299Jun 09, 2011 4:18 pm Can anyone tell me if they had the flooring included in their promo (Cat 1 Tiles, Cat 2 Carpet) but decided to source their own flooring elsewhere. Did PD give you a credit for not going ahead with them. Ivanhoe 36 Dep:18-4-11 Tender:26-5-11 Colour/Electrical:8-6-11 Contract:29-6-11 Building Permit:6-7-11 Site Start:16-8-11 PCI:10-1-12 Handover:24-1-12 http://eli-kay-ivanhoe36.blogspot.com/ Re: Porter Davis homes 2300Jun 09, 2011 4:26 pm eli-kay123 Can anyone tell me if they had the flooring included in their promo (Cat 1 Tiles, Cat 2 Carpet) but decided to source their own flooring elsewhere. Did PD give you a credit for not going ahead with them. i spoke to my CSC about a credit and she said no. i upgraded the tiles and carpet was close to wat we wanted. Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12357 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74719 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105617 |
