Browse Forums Building A New House Re: Building First Home with Simonds - Narre Warren, VIC 3May 31, 2011 11:29 pm hubby, kids and me all waiting for the Amberlea Site Cut 27 September 2011 https://forum.homeone.com.au/viewtopic.php?f=31&t=46637 http://www.dscml.com/ Re: Building First Home with Simonds - Narre Warren, VIC 4Jun 01, 2011 8:16 am My Hamptons build (completed): viewtopic.php?f=31&t=63370 Moved in Wednesday 11th Dec 2013 Front landscaping completed June 2016 Re: Building First Home with Simonds - Narre Warren, VIC 6Jun 01, 2011 8:39 am __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: Building First Home with Simonds - Narre Warren, VIC 10Jun 01, 2011 7:20 pm in case you are wondering, below is apparently what our house includes as standard. this will all need to be confirmed on the weekend of course. if you could asterisk anything below we need to be made particularly aware of would be fantastic. thanks again. Kitchen o Electric underbench oven (600mm) o Gas cooktop (600mm) o CHOICE: 600mm slide-out rangehood (with laminated overhead cabinets) OR 600mm canopy rangehood o 250mm exhaust fan including self sealing air flow draft stopper over cooktop (specific to Atherton 1500, Auburn 1500 and Auburn 1600) o 1¾ bowl stainless steel sink including basket waste o Fully lined laminated base with laminate post formed bench top including overhead cupboards (as per working drawings) o Stainless steel appliances o Mixer tap (selection of styles) o Dishwasher space with single power point and plumbing connection · Bathroom and Ensuite o Fully lined laminated base cabinet with laminate post formed or square edge benchtop o Vitreous china above counter hand basins (white) (selection of styles) o Acrylic designer bath (white) set in a tiled podium (selection of styles) o Dual flush vitreous china close coupled toilet suite (white) including skirted pan and enclosed trap o Polished edge mirrors (above vanity benchtop) o Showers - laminated glass pivot doors and colour matched frames with polymarble base o Pin lever mixer tapware (selection of styles) o Shower rose and 220mm wall bath outlet o 250mm exhaust fans including self sealing air flow draft stoppers to bathroom and ensuite · Laundry o Feature acrylic 45lt trough and cabinet (white) with tapware o Wall mounted washing machine taps · Ceramic Tiling (From Builders Standard Range) o Wall tiles to kitchen, bathroom, ensuite and laundry o Floor tiles to bathroom, ensuite, WC and laundry o 150mm high skirting tiles to bathroom, ensuite, powder room, WC and laundry (as per working drawings) · Windows and External Doors o Sliding aluminium windows including window locks o Solidcarve entry door o Push plate external door furniture including lever handle, deadlock, trim plate with logo and key in knob entry set to garage access door · Garage o Colorbond roller door to front o Weatherproof hinged flush panel access door · Insulation o R3.5 Glasswool batts to ceiling of roof space only (excludes garage) o R2.0 Glasswool wall batts including sisalation to external brick veneer walls (excluding garage) and wall between garage and house · Ceilings o 2440mm (overall plates) standard ceiling height · Stairs - 2 Storey o MDF treads and MDF rises paint finish (plan specific) o Balusters and handrail (house specific) · Solar Hot Water Service o 160lt Lo Line Gas Boosted with 20lt Continuous Flow Booster, 1 No. Solar Collector and the necessary electrical and plumbing connections. Note: Panel and storage tank positioned at the Builder's discretion. Additional solar panel maybe required at clients’ expense subject to orientation of dwelling · Roofing o Concrete colour on roof tile. Selection from Builders range o Zincalume Cliplock roofing to all flat roof construction (house specific) o Colorbond fascia and gutter · Fixing o 42mm MDF square dressed or pencil round architraves and 67mm MDF square dressed or pencil round skirtings o Flush panel doors o Lever passage sets and pull handles (selection of styles) o Hinged opening doors to wardrobes (as shown on plans) · Plaster o Cornice - 75mm cove · Paint - 2 Coat Application o Low sheen acrylic to external timber work o Low sheen acrylic to internal walls o Flat acrylic to ceilings (white optional) o Gloss finish to internal woodwork o Gloss finish to front entry and internal doors Note: Walls, woodwork and ceiling to be one colour throughout (white ceilings optional) · Foundations o Class 'M' concrete slab · Heating (Natural gas only) o Gas ducted heating unit in roof space o Gas wall heater (specific to Atherton 1500, Auburn 1500 and Auburn 1600) · Electrical o Double power points and batten light points as per standard electric layout o Safety switches (earth leakage detector) o Smoke detectors o Telephone point to kitchen o 1 No. TV point o 1 No. external light point outside laundry · Connection Costs o Connection of services - water, gas, electricity, sewer, telephone conduit and stormwater based on 650m2 blocks with 300mm fall and 5m setback. Does not include electricity and telephone consumer account opening fees o 2 No. external taps Re: Building First Home with Simonds - Narre Warren, VIC 11Jun 01, 2011 8:07 pm very nice plan. It will be a lovely home when it is completed. is your block not very deep? hubby, kids and me all waiting for the Amberlea Site Cut 27 September 2011 https://forum.homeone.com.au/viewtopic.php?f=31&t=46637 http://www.dscml.com/ Re: Building First Home with Simonds - Narre Warren, VIC 12Jun 01, 2011 8:23 pm yes not very deep. i believe it is what is referred to as a "cottage block" but we like the location so we decided to compromise on block size (depth) and build up hence double storey is our only option really... Re: Building First Home with Simonds - Narre Warren, VIC 13Jun 01, 2011 9:04 pm In regards to the post about things you might forget, the last updated post is here: viewtopic.php?p=705220#p705220 Print it off, it has some good things in it that you may wish to understand before agreeing to move forward (with any builder) Re: Building First Home with Simonds - Narre Warren, VIC 14Jun 01, 2011 9:07 pm My advise will be " not to build with them" you have plenty of other builders in the market -- they have 95% unhappy and 5% happy customers and thats the reason you hear a lot of negativity Re: Building First Home with Simonds - Narre Warren, VIC 15Jun 01, 2011 9:38 pm humble - thank you so much. that list certainly is extensive. lots in there i probably wouldn't have thought of.
abraham - thanks for your advice and i agree with your logic but no other builder seems to be any different on the internet. they all have negative feedback. it goes by the old saying that 10 people will give you a bad story for every 1 good story. people love to pass on bad news. even if it didn't happen to them but it happened to their friend's friend. how often do you hear good news stories on the news? maybe one little tidbit at the end of some panda bear that made friends with a monkey? the rest is war, famine, death, aids, carbon tax.... we found a nice reputable family builder and we were going to build with them but they don't do double storey and everyone else we can't afford. when we showed them the simonds plans they advised us to go ahead but be very careful. we have no choice but to go to a volume builder we just have to make sure they do a good job. i spoke about our concerns re volume builders with our lawyer / conveyancer (who is very good btw if you need these services in the eastern melbourne metro area) she put it in perspective. why would this company intentionally set out to build ** houses if they want to be building houses in 10-20 years time. it doesn't make very good business sense. you're destroying your brand your name. i think if we are smart about it we will be ok. she mentioned something about a 25 year guarantee. apparently your house comes with a 10 year guarantee of workmanship but you can ask to extend to 25 years. does anyone know anything about that? Re: Building First Home with Simonds - Narre Warren, VIC 16Jun 01, 2011 9:48 pm There are many people who have been happy with the build by Simonds. I am following one link http://forum.homeone.com.au/viewtopic.php?f=31&t=45132 on here and a blog http://waitingforlife2begin.blogspot.com/ I am in the s.e. Melbourne suburbs and we have different tradies to what other regions have and also there is currently lots tradies seeking work in our area as one of the estates in Cranbourne can't proceed yet as the estate has problems with the business side of things. Just when you start your build have an independent inspector at all steps from contract onwards , we are using New Home Inspections, and just like you said be on site often. You sound pretty level headed and know what you are in for. Simonds can produce some lovely homes. But like every other builder there can be some homes that are not finished to perfection, and these homes are the homes that we hear about. Don't let people on here get you down about the house you would like to build. Make it a fun adventure for you and your partner, and start a blog to document everything. our is http://www.dscml.com/ Also be aware that the base cost of the house you need to add between $50k to $80k on top of that again. When you are ready to start your build, start a new thread so we can all follow your build, can't wait to see. hubby, kids and me all waiting for the Amberlea Site Cut 27 September 2011 https://forum.homeone.com.au/viewtopic.php?f=31&t=46637 http://www.dscml.com/ Re: Building First Home with Simonds - Narre Warren, VIC 19Jun 01, 2011 10:09 pm edscl Also be aware that the base cost of the house you need to add between $50k to $80k on top of that again. we have money set aside on top but what does your estimate of 50k - 80k include? everything? like flooring / blinds / furnishing / landscaping / driveway / pavings etc? the good thing about having a small and level block and a reasonably compact house is we may be able to save on that aspect we thinks... Re: Building First Home with Simonds - Narre Warren, VIC 20Jun 01, 2011 10:15 pm mattnjaz edscl Also be aware that the base cost of the house you need to add between $50k to $80k on top of that again. we have money set aside on top but what does your estimate of 50k - 80k include? everything? like flooring / blinds / furnishing / landscaping / driveway / pavings etc? the good thing about having a small and level block and a reasonably compact house is we may be able to save on that aspect we thinks... With the base price you get nothing other than standard inclusion. The 50-80 include the upgrades - things what u hav mentioned plus colours(bricks etc), electrical I have posted this before: We hired Darbecca to do every stage inspection, and I strongly recommend them to anyone that asks me. They were amazing. Thorough reports… 2 4533 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27896 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8963 |
