Browse Forums Safer Living 1 May 21, 2011 7:02 pm I was trying to help a friend set up his Ness D8x alarm (with the touch screen keypad) and what we didn't read was that the pin code cannot start with "0". Because although we can program the pin code in, we can't use it to disarm the alarm. Problem now is, we found this out after we armed the alarm and we can't disarm it. I've tried to unplug the battery and switch the thing off and on again but this only brings it back to the armed state. Is there any factory reset button inside the alarm box? What can I do to fix this up? Re: Ness Alarm Factory Reset - Please Help! 2May 21, 2011 9:43 pm Hi, According to the manual: Quote: PROG/TAMP – Program Link & Internal Tamper Input The PROG/TAMP link appears on the two pin J1 header. The PROG/TAMP link has two purposes: 1. To enter Installer Program Mode on initial power up. Power-up with the PROG link OFF. The PROG link (or Box Tamper lead) must be ON in operating mode. So, I would try this:
You should now be in installer program mode and able to reset your master user code. Paul Re: Ness Alarm Factory Reset - Please Help! 3May 21, 2011 10:51 pm Thanks very much Paul, I'll try it tomorrow and I'll be sure to let you know if this works. Re: Ness Alarm Factory Reset - Please Help! 4May 22, 2011 7:56 pm Worked like a charm! Thanks very much Paul! Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 6621 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7614 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13242 |
