Browse Forums Laundry Appliances Re: Dryer box 2May 16, 2011 7:37 pm I'm having a hard time working out exactly what that product does. Are you looking for a venting kit? Something that vents to the outside of your house? You can go to Clive Peeters or Harvey Norman for a univeral dryer venting kit. Or you can buy them online. My blogs: http://www.movingtotasmania.com.au - a resource for those considering relocating to Tasmania http://www.sarahandtim.com - my daily life and renovation blog Re: Dryer box 3May 17, 2011 9:14 am sarahlou2 I'm having a hard time working out exactly what that product does. Are you looking for a venting kit? Something that vents to the outside of your house? You can go to Clive Peeters or Harvey Norman for a univeral dryer venting kit. Or you can buy them online. I have used the plsatic venting kits in the past that I believe you are referring to and have found soon as you move the dryer to clean behind it, it is a pain to reconnect it to the kit or if you get a new dryer, the vent is in a different position. The idea with the dryer box is so you can use a flexible tube and still push the dryer up against the wall, mind you our walls aren't as thick as the american's. Watch the video on the website above it explains it better. Matt. Re: Dryer box 4May 17, 2011 11:28 am After I posted my message I looked a bit further and asked my other half what the hell the box does. And then it became clear to me that in fact these seem quite useful. I never really thought about the fact that there is that bulk on the back of the dryer. Hmm you got me thinking about this now! My blogs: http://www.movingtotasmania.com.au - a resource for those considering relocating to Tasmania http://www.sarahandtim.com - my daily life and renovation blog Re: Dryer box 5May 17, 2011 11:34 am sarahlou2 After I posted my message I looked a bit further and asked my other half what the hell the box does. And then it became clear to me that in fact these seem quite useful. I never really thought about the fact that there is that bulk on the back of the dryer. Hmm you got me thinking about this now! Think I'll just fold one up myself out of thin sheet metal to fit the gap in the wall and paint it. Re: Dryer box 6May 18, 2011 12:01 pm Before we knocked our old place down, we ran the plastic ducting through the wall cavity like this. It had to run 45° because we had to put in a beam half across the laundry for our fridge alcove (it used to sit against the wall) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also when we bought it it did come with a formed duct to run the ducting behind it (was quite thin profile) but we lost it. New house will be similar but will run to vent through external wall rather than into ceiling and then to eave or through roof. The new ducting will be covered in by plaster (like a mini bulk head) When we cutout the holes in the wall we just fed the ducting through by hand. It was a bit hard as there was a water pipe behind the plaster (that we knew of so we knew to be careful and not cut through it. This looks like it would be great if it were the right price but if it as more than say $50 I'd still do it our original way. Looking at the specs though they may not fit a regular Aussie house wall as I think ours are 90mm thick including both sheets of plaster. These have a wall cavity depth of 90mm so it would stick out a bit. A very good idea though and I'm sure as someone said, you could make up something to suit with out too much drama. Re: Dryer box 7Jun 29, 2011 10:03 pm Thought I would post my progress, ducting done and working, also made the tray. About a 40mm gap when u push the dryer up against the wall which is perfect. Have used 100mm ducting. I still have to do the tiling and the bench. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Dryer box 8Jul 18, 2011 10:25 am I'm just re checking this for details so I'll answer some of your questions Rick, Tumble dryers are a popular back up for clothes drying, but most of the Aussie Population that lives in Suburbia would use a clothes line/Hills hoist/out door line. Our "standard" wall studs are usually either 70mm or 90mm thick with 450mm between studs. 70mm is the most common new build for internal walls unless specified. I'm not sure what the measurement is for steel frames. Internal Laundry is standard for all run of the mill new houses and I think has been since the 70's at least. One problem you may have to address is most new houses are built on concrete slabs here and with timber frames you need to find a way of getting through the timber top plate without cutting a piece out(no point having a big gap in the thing that holds you r house up is there) Also it very common to wall mount (inverted/upside down) our dryers here. Re: Dryer box 9Jul 18, 2011 11:16 am chrisandkate Before we knocked our old place down, we ran the plastic ducting through the wall cavity like this. It had to run 45° because we had to put in a beam half across the laundry for our fridge alcove (it used to sit against the wall) I would be a little concerned that plastic ribbed ducting like that would be a fire hazard over time, unless the dryer is a condenser type the outlet can get quite hot, add a buildup of lint to the mix and it might get dangerous? Re: Dryer box 10Jul 20, 2011 9:08 am Yes it would have been, but we modified it slightly. We found that there was still a considerable amount of lint getting caught in the ducting with the moisture that is also vented. To fix this potential issue we made a mesh screen to sit between the dryer and ducting against the wall. Just lift/tilt the dryer toward the ceiling and pull out the screen, clean it and put it back. I used a fabric mesh that was similar to that of the lint catcher in the dryer. I'll be using the same sort of set up in the new house. Also the plastic ducting did get warm but not hot. In my opinion the extra lint trap removed 95% percent of the issue of potential fire hazard. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 42526 I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 10854 |
