Browse Forums Bathrooms and Laundry 1 May 06, 2011 7:46 pm Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 3May 06, 2011 9:21 pm Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 6May 06, 2011 10:14 pm Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 8May 06, 2011 10:24 pm Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 9May 06, 2011 10:25 pm Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 12May 06, 2011 11:07 pm Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 15May 07, 2011 8:21 am Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 17May 08, 2011 1:36 pm Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: I need MAJOR help with my tile choices 19May 15, 2011 11:29 am Hi acrebuild Have you got any further in finding the right tile? I just read your blog &, working for a tile business, I had some ideas!. I think if you are after a marble look, perhaps with a bit of texturing as a feature wall & in cooler tones to go with your other finishes, you could achieve all of these using a full bodied porcelain tile which has a bit of pattern to look like natural stone. You could use a 300 on the floor with a 300x600 on the wall. If you like a marble look you might go for the polished finish (some will need sealing but this is effective) and there are a number of colour options that would co-ordinate with your bench/cabinetry. If you like the idea of black, you could consider using the black on the floor and a lighter off white/grey on the walls so as to keep the space light (or the lighter tile on both floor & wall to make the space look bigger). Then if your lighting is good enough you could add drama with a textured darker feature wall (perhaps behind the vanity). Anyway - just some ideas. If you have a swatch of your other finishes, I suggest you visit Lindsay at our Amber Maitland store and you could have a play around to see how it all works together! Hope this helps & hope you achieve your dream bathroom!! Looking for advice on whether this variation in tile colour is acceptable. The large tile on the left was used in my main bathroom renovation 1 year ago. My ensuite… 0 8732 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6731 |
