Browse Forums Landscape & Garden Design Re: SOAKWELLS - How easy are they to put in and install ? 87May 13, 2011 4:07 pm Kmax It seems such a good solution to drainage in an area that has very little access and isn't it recycling . Some of the local councils are even recommending it as an option. To be perfectly blunt, they're wrong. Fu help me out here :p Re: SOAKWELLS - How easy are they to put in and install ? 88May 13, 2011 4:24 pm Ok, need some help then. The problem is access to the area and volume of storm water. The storm water is from a large Box Gutter and a recently added extension to my home does not allow much access around the back of the house were the s/w is going, (I also have to consider a concrete pool that is in this area as well) I will have great difficulty trying to manouvering any size concrete s/w into this area. Due to the volume of water that comes from the box gutter, I think the alternative polypropylene options will not be suitable. Re: SOAKWELLS - How easy are they to put in and install ? 91May 14, 2011 1:20 am Interconnect the pipes from each open downpipe and bring it out to a more open area where you can put soakwells in. Re: SOAKWELLS - How easy are they to put in and install ? 92May 15, 2011 11:07 pm There is no way using tyres would be a good idea. The chemicals they leach into the soil is not cool. Re: SOAKWELLS - How easy are they to put in and install ? 93May 16, 2011 2:37 am Guys, not advertising or anything, but in case anyone from Perth needs soakwells - I have 3 crate style covered in geofabric for $40 each - leftover from my project (overordered). These are superb and normally you get them for $55. PM me if interested Re: SOAKWELLS - How easy are they to put in and install ? 95Jun 03, 2011 2:06 pm My neighbour has a gap of 200mm to the boundary plus standard garage coloumn width. He is doing a soakwell after driveway has been laid and fencing is on. Is that enough of a gap to install a soakwell and well that soakwell being so close to the boundary affect the fence and both our driveway. Re: SOAKWELLS - How easy are they to put in and install ? 96Jun 05, 2011 11:53 pm The depth is the only thing to worry about. 300mm plus. Re: SOAKWELLS - How easy are they to put in and install ? 97Jun 10, 2011 4:47 pm Fu or anyone else, a quick question. I need to install soakwells on the 18th/19th June and i was looking at doing it DIY through these guys: http://www.soakwellsolutions.com.au/diy.html My new house is in the city of cockburn and by their requirements my calculations show that i need 40 soakwell units!! http://www.allaboutsoakwells.com/counci ... ckburn.pdf This is going to blow my installation to over $2000. is this right? The soakwells are poly ones : 400x450x600 Roof Cover: 335 m2 Does 40 sound right or is it overkill. from my understanding, i thought i only needed one unit per downpipe. Is the figure higher because it is for concrete soakwells. Due to higher leaching rate of the poly soakwells would i need less of them? Re: SOAKWELLS - How easy are they to put in and install ? 98Jun 11, 2011 11:49 pm have I mentioned these in any of these threads? Flotank, flow cell? http://www.atlantiscorp.com.au/trade-products/flo-tank It gets no better than these. They will hold several tonne so can go under a drive. They will also allow more water out into the soil faster than any other form of drainage. Re: SOAKWELLS - How easy are they to put in and install ? 99Jun 12, 2011 3:27 am Fu what makes those ones better than the ones from soakwell solutions. I won't be having any soakwells under driveway. Also, is one poly soakwell per downpipe enough? Re: SOAKWELLS - How easy are they to put in and install ? 100Jun 12, 2011 8:46 pm You'd be pretty under gunned. Personally I'd be using tropical guttering and 100mm down pipes. I'd be interconnecting all the flo tanks. However not many homes have that available. Perth is in for a hell of a change. We will see far less rainfall (estimated to be between 30% and 60% less than now in the next 15-30 years). However we will see far greater rainfall rates. The storms of March 2010 and Feb this year will become more common however they were at the extreme end of the scale. So it makes sense to prepare for that and think ahead. Soakwell solutions use a whole variety of different types of soak wells. Atlantiscorp is the producer not the supplier of flo tanks to the best of my knowledge. Of course who ever is cheapest, but it's that style of tank/well that is what is really needed. DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 41789 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8877 0 12266 |
