Browse Forums Paving & Concreting Re: ISSUE WITH CONCRETING PLS HELP. 2May 02, 2011 4:18 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: ISSUE WITH CONCRETING PLS HELP. 7May 03, 2011 6:45 pm Kvm2011 yes we have to cut the concrete but are bit hesitant as have not done this before ? DIY ???? Fairly easy DIY job for small jobs cut conctete with a concrete cutting blade on a large angle grinder and then break up with sledge hammer. for larger work hire a demolition saw. Wear goggles and a face mask as there will be lots of dust. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8240 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4459 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9142 |
