Browse Forums Safer Living Re: Which Home Alarm system? 2Mar 17, 2011 4:56 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Which Home Alarm system? 6Apr 10, 2011 8:37 pm deeps So I've been getting some quotes for home security systems, and after compiling a table, I've got to make a decision. I do have two more quotes to come, but I expect it to be about the same. Our initial budget was $1000, but we can't seem to squeeze some keyfobs into that price unfortunately. We are willing to stretch it a bit though so no big problem there. Which of these systems are the best, and are the prices reasonable? Deeps You might wish to get more quotes as you have not given the correct information to us all, if you are going to monitor the system with your mobile you will need a system that can handle it, that means a ness system, they are designed for monitoring with a mobile, if you want the hills system then you will require "operator software" (around $250), also the quote I gave you included an NX16 panel (you are not comparing horses with horses) Telecommunications systems, computer Networks and Security systems. Re: Which Home Alarm system? 7Apr 11, 2011 12:17 pm Databoom deeps So I've been getting some quotes for home security systems, and after compiling a table, I've got to make a decision. I do have two more quotes to come, but I expect it to be about the same. Our initial budget was $1000, but we can't seem to squeeze some keyfobs into that price unfortunately. We are willing to stretch it a bit though so no big problem there. Which of these systems are the best, and are the prices reasonable? Deeps You might wish to get more quotes as you have not given the correct information to us all, if you are going to monitor the system with your mobile you will need a system that can handle it, that means a ness system, they are designed for monitoring with a mobile, if you want the hills system then you will require "operator software" (around $250), also the quote I gave you included an NX16 panel (you are not comparing horses with horses) Uh What?? Ness systems arent the only systems that you can monitor via a mobile, hills systems can be monitored via phone without spending any money on some so called operator software. Plug your phone line in, program it up to call a mobile it is pretty simple. The majority of alarm systems on the market can be programmed up to ring a mobile. We have installed hundreds of hills alarms to do this. Just curious for a house why would you quote to install a NX16? Isnt that a little overkill, I'm sure an 8 will do just fine. Re: Which Home Alarm system? 9Apr 13, 2011 3:37 pm Hi Lakgar, what area are you in? The reason I ask is if you go through a local security company that has been around for a few years you will find that there prices and customer service are alot better than one of the bigger companies like Signal Security. Another downfall with the bigger companies is they want you to sign a contract. Usually they sucker you in by giving you a free alarm system but signing you up on a monitoring contract where you have to stay with them for a minimum of 3 years whilst paying a higher rate than most monitoring centres charge. Which means you end up paying for the alarm system 3 times over. Re: Which Home Alarm system? 10Apr 13, 2011 3:46 pm TUBBYM Hi Lakgar, what area are you in? The reason I ask is if you go through a local security company that has been around for a few years you will find that there prices and customer service are alot better than one of the bigger companies like Signal Security. Another downfall with the bigger companies is they want you to sign a contract. Usually they sucker you in by giving you a free alarm system but signing you up on a monitoring contract where you have to stay with them for a minimum of 3 years whilst paying a higher rate than most monitoring centres charge. Which means you end up paying for the alarm system 3 times over. Hi TUBBYM, I am in Williams Landing stage 5. I was going with big company as I had read that small companies might close down without notice....so just to be on safe grounds. Do you know any security companies that service Williams Landing area? Thanks. Re: Which Home Alarm system? 11Apr 14, 2011 8:37 am lakgar TUBBYM Hi Lakgar, what area are you in? The reason I ask is if you go through a local security company that has been around for a few years you will find that there prices and customer service are alot better than one of the bigger companies like Signal Security. Another downfall with the bigger companies is they want you to sign a contract. Usually they sucker you in by giving you a free alarm system but signing you up on a monitoring contract where you have to stay with them for a minimum of 3 years whilst paying a higher rate than most monitoring centres charge. Which means you end up paying for the alarm system 3 times over. Hi TUBBYM, I am in Williams Landing stage 5. I was going with big company as I had read that small companies might close down without notice....so just to be on safe grounds. Do you know any security companies that service Williams Landing area? Thanks. I am also still surveying for 1. Still haven't decided on it yet as our future home not started building... But I know there is one in hoppers crossing: http://www.safe-guard.com.au You may try this... ___________________ Building with Carlisle Homes, Montrose 36 in Point Cook http://www.pointcookfb.blogspot.com/ Re: Which Home Alarm system? 12Apr 14, 2011 6:56 pm lakgar TUBBYM Hi Lakgar, what area are you in? The reason I ask is if you go through a local security company that has been around for a few years you will find that there prices and customer service are alot better than one of the bigger companies like Signal Security. Another downfall with the bigger companies is they want you to sign a contract. Usually they sucker you in by giving you a free alarm system but signing you up on a monitoring contract where you have to stay with them for a minimum of 3 years whilst paying a higher rate than most monitoring centres charge. Which means you end up paying for the alarm system 3 times over. Hi TUBBYM, I am in Williams Landing stage 5. I was going with big company as I had read that small companies might close down without notice....so just to be on safe grounds. Do you know any security companies that service Williams Landing area? Thanks. Thats fair enough, but there are alot of small companies which have been round for a number of years, its just a good way to save some money. Off the top of my head I dont know of many companies out there. The company I work for has been out that way a few times but it is pretty far to travel. Best bet is to do a google search, or yellow pages. Re: Which Home Alarm system? 13Apr 14, 2011 8:18 pm If you are in Perth and looking for system and monitoring, PM me, I managed to get a nice deal on a Bosch system Re: Which Home Alarm system? 14Apr 16, 2011 5:29 pm I am in Melbourne, deeps. I have decided on back to base monitoring with a company, Securetrac. They are giving 1st month free monitoring and then $33/month after that on a 2 year contract. Before finalising with them, just wanted to know are there any tricky bits about a security system installation that I should get clarified??? Re: Which Home Alarm system? 15Apr 16, 2011 9:42 pm lakgar I am in Melbourne, deeps. I have decided on back to base monitoring with a company, Securetrac. They are giving 1st month free monitoring and then $33/month after that on a 2 year contract. Before finalising with them, just wanted to know are there any tricky bits about a security system installation that I should get clarified??? $33 a month is a little steep, majority of control rooms charge $1 a day, I know its only a few dollars extra but at the end of the day it all adds up. Re: Which Home Alarm system? 17May 05, 2011 5:20 pm TUBBYM Databoom deeps So I've been getting some quotes for home security systems, and after compiling a table, I've got to make a decision. I do have two more quotes to come, but I expect it to be about the same. Our initial budget was $1000, but we can't seem to squeeze some keyfobs into that price unfortunately. We are willing to stretch it a bit though so no big problem there. Which of these systems are the best, and are the prices reasonable? Deeps You might wish to get more quotes as you have not given the correct information to us all, if you are going to monitor the system with your mobile you will need a system that can handle it, that means a ness system, they are designed for monitoring with a mobile, if you want the hills system then you will require "operator software" (around $250), also the quote I gave you included an NX16 panel (you are not comparing horses with horses) Uh What?? Ness systems arent the only systems that you can monitor via a mobile, hills systems can be monitored via phone without spending any money on some so called operator software. Plug your phone line in, program it up to call a mobile it is pretty simple. The majority of alarm systems on the market can be programmed up to ring a mobile. We have installed hundreds of hills alarms to do this. Just curious for a house why would you quote to install a NX16? Isnt that a little overkill, I'm sure an 8 will do just fine. Sure a hills system can dial up a mobile, heck a dumb modem can but...... If you really have installed hundreds of hills systems then you would also know that the hills system cannot be "kissed off" with a smart phone, and if you have in fact sold systems to people and programmed them to shut down dialling after two attempts (the only way to stop them dialling due to smart phones not being able to kiss them off), your customers are probably all wondering why the "service light" will not go off. Why did I install an NX 16 well deeps indicated that he may want to expand in the future and as a professional I would naturally allow for expansion, from my experience a lot of so called security professionals supply and install systems exactly to the customers specifications, that way they keep it cheap and get the job, however I take my profession seriously enough to advise people to allow for the future expansion, even if it costs me the job and as licensed consultants we are legally bound to give the client good advice, sadly there many in the industry that aren't trained correctly or just don't care once they have installed a system. Telecommunications systems, computer Networks and Security systems. Re: Which Home Alarm system? 18May 09, 2011 6:50 pm Databoom TUBBYM Databoom So I've been getting some quotes for home security systems, and after compiling a table, I've got to make a decision. I do have two more quotes to come, but I expect it to be about the same. Our initial budget was $1000, but we can't seem to squeeze some keyfobs into that price unfortunately. We are willing to stretch it a bit though so no big problem there. Which of these systems are the best, and are the prices reasonable? Deeps You might wish to get more quotes as you have not given the correct information to us all, if you are going to monitor the system with your mobile you will need a system that can handle it, that means a ness system, they are designed for monitoring with a mobile, if you want the hills system then you will require "operator software" (around $250), also the quote I gave you included an NX16 panel (you are not comparing horses with horses) Uh What?? Ness systems arent the only systems that you can monitor via a mobile, hills systems can be monitored via phone without spending any money on some so called operator software. Plug your phone line in, program it up to call a mobile it is pretty simple. The majority of alarm systems on the market can be programmed up to ring a mobile. We have installed hundreds of hills alarms to do this. Just curious for a house why would you quote to install a NX16? Isnt that a little overkill, I'm sure an 8 will do just fine. Sure a hills system can dial up a mobile, heck a dumb modem can but...... If you really have installed hundreds of hills systems then you would also know that the hills system cannot be "kissed off" with a smart phone, and if you have in fact sold systems to people and programmed them to shut down dialling after two attempts (the only way to stop them dialling due to smart phones not being able to kiss them off), your customers are probably all wondering why the "service light" will not go off. Why did I install an NX 16 well deeps indicated that he may want to expand in the future and as a professional I would naturally allow for expansion, from my experience a lot of so called security professionals supply and install systems exactly to the customers specifications, that way they keep it cheap and get the job, however I take my profession seriously enough to advise people to allow for the future expansion, even if it costs me the job and as licensed consultants we are legally bound to give the client good advice, sadly there many in the industry that aren't trained correctly or just don't care once they have installed a system.[/quote] Umm who told you smart phones cant kiss of the systems?? Hold down the * key for about 3 seconds once the tone breaks. I have never come across a smartphone that cant do it. I understand future expansion and all but a 16 is massive overkill, for a normal house a 8 for be fine if the house is larger then use a 12. Re: Which Home Alarm system? 19Jun 16, 2011 12:44 pm who told me? Direct alarm supplies try to get them to confirm what you are saying, they will not support this. And also I must direct you to the terms and conditions for posting on this site. Telecommunications systems, computer Networks and Security systems. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16295 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19522 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9798 |
