Browse Forums Building A New House Re: Storm Water Drainage - connection 5Mar 18, 2011 9:50 pm Lex No idea, but it seems that you also need to check with your Council. They may be able to offer some advice. You don't mention this, but I suppose your SW would be coming from the whole roof area of your house and garage, not just from some additional small-scale pergola roof, or small-scale sections of soil drainage (which could, in most cases, simply be diverted into a pit or sometimes into a sloping yard area)? In some old built-up areas, the SW discharge points are scarce. It gets tricky when one has to push water uphill to get to a legal discharge point - or rather, create a pit of some kind in their own property. Or, in your case, as your builder wants, across other properties. Thanks Lex. Re: Storm Water Drainage - connection 6Mar 18, 2011 9:54 pm Has anyone had the storm water legal point of discharge not in their backyard but in the neighbours backyard or in the nearby street. If so was the cost of creating legal point of discharge is passed on to you by builder or builder takes the cost? Did the neighbour refuse? Thanks Yellow Re: Storm Water Drainage - connection 7Mar 23, 2011 1:51 pm Hi Yellow,Had to go thru neighbours as well,now have to put in our own stormwater tanks,we are planning to do this ourselves after handover,were a long time away from that at moment,so have no idea how much it will end up costing us.Has already cost $660 for engineering drawings to be done(thru builder) so that it could be shown on plan for shire.It kinda sucks.We have to have 3 tanks and a subsoil overflow.Anybody would think we were colecting stormwater for whole of street 1500 dia x 1200 depth volume 6.36 House is 280sq mtrs on a slight slope/clay and other side we have to have a subsoil drainage which is to run legth of house at $5500(being done by builder). If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 12491 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 21129 |
